Should I always manually transmit the use_sim_time manually to all my nodes in a launchfile in ROS 2, if I want to be able to slow down or accelerate the simulation time or be able to run it on rosbags ?
The only official example I have is from the robot state publisher tutorial, where it is transmitted manually.
But I would expect a way to setting it globally, since it is the entierity of a ROS 2 system that should affected by time when you slow down or accelerate a simulation, or replay a rosbag. And because it is repetitive and add length to the code.
Is there such a way instead ?
Originally posted by deb0ch on ROS Answers with karma: 101 on 2021-02-09
Post score: 7
Comment by ottojo on 2021-04-23:
Hi! Did you since find a way to set use_sim_time globally (besides setting it in the launchfile)?
Comment by austin on 2021-04-25:
It would be convenient to have a global use_sim_time. However its up to each node to implement so i am not sure this is even possible or desirable.
however ever robot i have seen is has to pass it throughout the launch ecosystem because to your point it really does effect everything. I alsot breaks if every node is not on the same use_sim_time param. So de facto there is a global use_sim_time concept.
Therefore i think this is a good feature request and would require updated to rclcpp and rclpy i think. somewhat related and definitly good place for more info on the client library implementations of ros time: https://github.com/ros2/rclcpp/issues/595
3 Answers 3
Can set_parameter solve this problem? #q368802
Originally posted by Kenji Miyake with karma: 307 on 2021-04-25
Hey ! Nice to see some movement around this question !
Since I posted, we found a neat solution that works great for us : using the /**: syntax in the .yaml params file, where ** matches the names of all the nodes :
params/simulation.yaml
    ros__parameters:
        use_sim_time: true
launch/do_stuff.launch.py
import os
from ament_index_python.packages import get_package_share_directory
from launch_ros.actions import Node
    """Launch stuff using ROS 2."""
    params = os.path.join(get_package_share_directory('your_package'), 'params', 'simulation.yaml')
    return LaunchDescription([
        Node(
            package='stuff',
            executable='do_stuff_node',
            name='do_stuff',
            parameters=[params],
            output='screen'),
Originally posted by deb0ch with karma: 101 on 2021-04-26
Comment by NEngelhard on 2022-01-13:
but how do you use this if your node has it's own parameter file?
See this PR for an alternative solution. @NEngelhard
