How is package:// in an URDF file resolved in ROS 2, i.e. what do I need to put there so that the files are found?
Some context:
With ROS 1 I was using package://package_name/meshes/file.stl in the URDF file with a directory "meshes" at the root of the package. This was working fine using the devel space.
Now with ROS 2, I am installing the meshes with
install(DIRECTORY meshes DESTINATION share/${PROJECT_NAME})
so they end up in install/package_name/share/package_name/meshes.
Unfortunately, when loading the URDF, they are not found. I assume, I need to adjust the package://... part. I already tried package://package_name/share/package_name/meshes without success.
Originally posted by Felix Widmaier on ROS Answers with karma: 382 on 2021-01-22
In ROS 2 packages are found using the .ament resource index (design doc here). First there needs to be a marker file in the packages folder.
Second, I assume you're doing an isolated build with colcon (which is the default), in which case your package's install prefix is install/package_name. Add another share and package_name and the URI package://package_name/meshes/file.stl should resolve to install/package_name/share/package_name/meshes/file.stl, which means it should have been installed to share/package_name/meshes.
How it works:
The package resource_retriever is used by other packages to resolve package:// URIs. It calls ament_index_cpp::get_package_share_directory(). That's implemented here. In short, it returns a string like <package prefix>/share/<package_name>.
In your example I assume you're doing an isolated build with colcon (which is the default), in which case your package's install prefix is install/package_name. Add another share and package_name and the URI package://package_name/meshes/file.stl should resolve to install/package_name/share/package_name/meshes/file.stl, which means it should have been installed to share/package_name/meshes.
How to create a marker file
How to create a marker file depends on the build type in the package.xml
  <export>
    <build_type>...</build_type>
  </export>
Build type: ament_cmake
ament_cmake packages automatically install the marker file. You only need to call ament_package(). It happens inside ament_package(), but not in a straightforward way. It invokes extensions, which calls an extension ament_cmake_index_package_hook() because ament_cmake_core registered it with itself, which ultimately calls ament_index_register_package(). I don't know why ament_package() goes through the extensions instead of calling ament_index_register_package() directly.
Build type: cmake
I don't know of a plain CMake package example to link to, but this should work.
Create an empty file with the same name as your package (example below assumes it's in a folder called resource adjacent to your CMakeLists.txt), then install it to share/ament_index/resource_index/packages/resource.
install(FILES resource/my_package_name
 DESTINATION share/ament_index/resource_index/packages/resource
Build type: ament_python
Python packages install the markerfiles themselves.
Create an empty file with the same name as your package in the repo, then install it using the data_files argument of setup().
data_files=[
    ('share/' + package_name, ['package.xml']),
    ('share/ament_index/resource_index/packages',
        ['resource/' + package_name]),
Related questions
https://answers.ros.org/question/367328/
Originally posted by sloretz with karma: 3061 on 2021-01-22
Comment by Felix Widmaier on 2021-01-25:
Thanks for your elaborate answer! So apparently I was already doing everything correctly. And indeed, after doing a clean rebuilt, it is not working without further changes... I have no idea what the problem was last week.
Comment by concaveros on 2021-08-28:
In my case, adding <gazebo_ros gazebo_model_path="${prefix}/.."/> to my package.xml similar to the turtlebot3-description-reduced-mesh package fixed the issue.
