Followed the tutorial, adapted it to my project. When I call the advertiseService in the main, it works. When it is called in a function called by main, it doesn't.
Here some code. First, tutorial example which works :
#include "ros/ros.h"
#include "testService/AddTwoInts.h"
bool add(testService::AddTwoInts::Request  &req, testService::AddTwoInts::Response &res)
  res.sum = req.a + req.b;
  ROS_INFO("request: x=%ld, y=%ld", (long int)req.a, (long int)req.b);
  ROS_INFO("sending back response: [%ld]", (long int)res.sum);
  return true;
  ros::init(argc, argv, "add_two_ints_server");
  ros::NodeHandle n;
  ros::ServiceServer service = n.advertiseService("add_two_ints", add);
  ROS_INFO("Ready to add two ints.");
  ros::spin();
  return 0;
In my use case, I need to set up a service in a separate file. I"m surprised this doesn't work
void testFunction(ros::NodeHandle &n);
  return true;
  ros::NodeHandle n;
  testFunction(n);
  ros::spin();
  return 0;
The service doesn't show up when typing rosservice list.
First, I made a new node handle in my function. Then, I tried to pass the main's node Handle by value, reference, pointer, global variable to my function. No changes. I thought about creating a function returning an object with topic name and function pointer inside it, but function pointer callback are callback-specific and my main can't know their type. Any one got a lead to how to do this?
Originally posted by Vic on ROS Answers with karma: 71 on 2021-01-19
Comment by Delb on 2021-01-19:
Can you edit your question to show us your code ?
The problem is because you declare and define the service within the function testFunction, so once the function is finished the service goes out of scope and doesn't exist anymore.
If you sleep some time in your function you will see that the service exists while you are still in the function :
  ros::Rate r(0.2); //Sleep for 5 seconds
  r.sleep();
About your issue :
I'm not sure to get why setting up a service in a separate file requires you to use a function like in your example. Maybe you could add more details about this. I would recommend creating a class in your separate file that would have ros::ServiceServer as member so that when you create an instance of this class in your main the service is kept alive.
Originally posted by Delb with karma: 3907 on 2021-01-19
Comment by Vic on 2021-01-19:
Thanks for the quick feedback.
For the posterity : this works
class testClass
public:
  ros::ServiceServer service;
testClass testScope;
  return true;
  ros::NodeHandle n;
  testFunction(n);
  ros::spin();
  return 0;
  testScope.service = n.advertiseService("add_two_ints", add);
