Hi, I am trying to use ROS navigation stack with RPlidar A2. currently, I am running gmapping with move_base and explore_lite so that robot can do auto-exploration and do SLAM. the problem is, even though I set allow_unkown to false in dwa_local_planner_params.yaml, the path generated by move_base is going through the unknown space (I also checked the value being false with rosparam get) Thank you for your help!
This is my costmap_common_parmas.yaml
obstacle_range: 2.5 #maximum obstale size
raytrace_range: 3.0 #robot will clear out space up to 3 meters
footprint: [[-0.30,-0.177], [0.105,-0.177], [0.105, 0.177], [-0.30,0.177]] #not sure, from legacy
robot_radius: 0.2
inflation_radius: 0.3 #0.55
observation_sources: laser_scan_sensor
laser_scan_sensor: {sensor_frame: laser_frame, data_type: LaserScan, topic: scan, marking: true, clearing: true}
This is my global_costmap.yaml
global_costmap:
  global_frame: map
  robot_base_frame: base_link
  update_frequency: 5.0
This is my local_costmap_params.yaml
local_costmap:
  global_frame: odom # NEW!! odom
  publish_frequency: 2.0
  static_map: false
  rolling_window: true # will remain centered around the robot as the robot moves around
  width: 5.0 #meters
  height: 5.0
  resolution: 0.01 #tend to set them equally as the static map
  static_map: true #if we use map_sever, keep it true
and I am using dwa_local_planner and A* for global_planner.
EDIT
After accepting the answer, I worked on properly setting the costmap yaml files and now it works properly. I have played with 'track_unkown_space' param and I decided to set them like these. These are the files I have written.
common_costmap.yaml
robot_radius: 0.2
global_costmap.yaml (here, I set 'track_unkown_space' to true, since I wanted A* planner to only plan in known & free space) - make sure you load these in move_base.xml file with namespace global_costmap.
global_frame: map
update_frequency: 3.0
  # obstacle_layer: {enabled: true, lethal_cost_threshold: 100, track_unknown_space: true, unknown_cost_value: -1}
  # static_layer: {enabled: true, lethal_cost_threshold: 100, track_unknown_space: true, unknown_cost_value: -1}
plugins:
- {name: static_layer, type: "costmap_2d::StaticLayer"}
- {name: obstacle_layer, type: "costmap_2d::ObstacleLayer"}
- {name: inflation_layer, type: "costmap_2d::InflationLayer"}
static_layer:
  unknown_cost_value: 0 # default: 0
  lethal_cost_threshold: 100 # default: 100
  map_topic: map # default: "map"
obstacle_layer:
  combination_method: 1 #default 1, meaning we will combine the layers
  map_type: costmap
  laser_scan_sensor:
    sensor_frame: laser_frame                 # default: ""
    topic: scan               # or /scan?
    data_type: LaserScan                # default: "PointCloud"
    marking: true                       # default: true
    clearing: true                      # default: false
inflation_layer:
  inflation_radius: 0.45 # default: 0.55
local_costmap.yaml (here, I set 'track_unknown_space' to false, since DWA planner works fine with this param being false.) I got this idea from this link text
global_frame: map # NEW!! odom
static_map: false
width: 5.0 #meters
height: 5.0
plugins:
obstacle_layer:
  track_unknown_space: false
  map_type: costmap
  laser_scan_sensor:
inflation_layer:
EDIT 2 I just wanted to say that explore_lite won't work with this setting as explore_lite sets unkown area as goals. If I set the allow_unkown to true, so that I could use explore_lite, the path generated wasn't appropriate as you can see in the picture. However, the above setting with costmap layers works great with general navigation stack when given goals in know & free space, so I am trying to find exploration method that works with only known&free move_base goal. image description
Originally posted by So Young on ROS Answers with karma: 118 on 2021-01-12
Comment by So Young on 2021-01-12:
I've seen some posts about setting track_unknown_space to true, but since my costmap doesn't have layers, I thought wouldn't need to worry about that parameter. (or maybe I'm understanding it wrong)
As you may have seen, the documentation for global_planner states:
~<name>/allow_unknown (bool, default: true)
    Specifies whether or not to allow the planner to create plans that traverse unknown space. NOTE: if you are using a layered costmap_2d costmap with a voxel or obstacle layer, you must also set the track_unknown_space param for that layer to be true, or it will convert all your unknown space to free space (which planner will then happily go right through)
What you may have missed is that your cost map does contain layers, even when defined with pre-Hydro parameters. From the costmap_2d wiki:
Pre-Hydro Parameters
Hydro and later releases use plugins for all costmap_2d layers. If you don't provide a plugins parameter then the initialization code will assume that your configuration is pre-Hydro and will load a default set of plugins with default namespaces. Your parameters will be moved to the new namespaces automagically. The default namespaces are static_layer, obstacle_layer and inflation_layer. Some tutorials (and books) still refer to pre-Hydro parameters, so pay close attention. To be safe, be sure to provide a plugins parameter.
Therefore, it seems you'll still need to set track_unknown_space to true in the obstacle_layer namespace.
Originally posted by tryan with karma: 1421 on 2021-01-13
Comment by So Young on 2021-01-13:
Thank you, yes I didn't know my costmap had default layers. I'll try to set them properly and also set track_unkown_space and see if it works!
Thank you for helping me with this problem, I have fixed the costmap yamls and now it works properly. I have also edited my post. Thanks!
