To Whom It May Concern,
I'm trying to use the ur10 CB series with polyscope version 3.12, Universal_Robots_ROS_Driver, ROS-Kinetic, Ubuntu 16.04. I do not want to use moveit to control the hardware. I want to use my own optimal controller to send joint velocity commands to the UR10. I have changed the ur10_bringup.launch file so that the joint_group_vel_controller is started.
ur10_bringup.launch file:
<?xml version="1.0"?>
<launch>
    <arg name="debug" default="false" />
    <arg name="robot_ip"/>
    <arg name="reverse_port" default="50001"/>
    <arg name="script_sender_port" default="50002"/>
    <arg name="tf_prefix" default="" doc="tf_prefix used for the robot."/>
    <arg name="controllers" default="joint_state_controller scaled_pos_joint_traj_controller
        speed_scaling_state_controller force_torque_sensor_controller"/>
    <arg name="stopped_controllers" default="pos_joint_traj_controller joint_group_vel_controller"/>
    <arg name="controller_config_file" default="$(find ur_robot_driver)/config/ur10_controllers.yaml"/>
    <arg name="robot_description_file" default="$(find ur_description)/launch/ur10_upload.launch"/>
    <arg name="kinematics_config" default="$(find ur_description)/config/ur10_default.yaml"/>
    <arg name="limited" default="false"/>
    <arg name="headless_mode" default="false"/>
    <include file="$(find ur_robot_driver)/launch/ur_common.launch" pass_all_args="true">
    <arg name="use_tool_communication" value="false"/>
</include>
I've confirmed my control rate is publishing commands to the joint_group_vel_controller/command at ~125HZ. First, why are script_sender_port & reverse_port default values 50002 & 50001 respectively? In the official remote control Universal Robots support articles (https://www.universal-robots.com/articles/ur/remote-control-via-tcpip/ ), it states to use ports 30*** for reading & writing data. It never mentions any values in the 50*** range, so where did the 50001 & 50002 values come from?
Lastly, I've confirmed my optimal controller can properly interpret joint position & velocity commands in Gazebo. The ur10 will move in the simulation whenever a command is sent, and there are no jerky/vibrating motions. When, I test on actual hardware the joint velocity commands are smooth, however the joint positions commands cause the non-smooth motion to occur. Should I look at optimizing my PID gains? Do you have any recomendation on where to look to optimize these values for a ur10, or a baseline to start at?
I would apperciate any support trying to get smoother motion.
Originally posted by StewartHemm74 on ROS Answers with karma: 46 on 2021-01-12
First:
Please refrain from doing this in future questions. The title of your question mentions jerky movement, but then you ask specific details about some of the networking infrastructure used. ROS Answers is a Q&A site, which works best with a 1-to-1 ratio of questions and answers. Including multiple questions in a single post doesn't work.
Having written that: tcp://:50001 and tcp://:50002 serve a very different purpose from the ports you refer to. They don't carry the same information and are specific to how the driver works. They are used for sending data to the controller, and must be opened on the ROS side, as URScript cannot listen on sockets, only connect.
That's nice, but almost irrelevant. Gazebo doesn't simulate the controller, networking infrastructure nor URScript or the URCap. Dynamic behaviour of the robot will be only approximately comparable. Using Gazebo is a good first step, but I would not take the fact that things "work in there" as conclusive evidence everything is OK with your code.
seeing as you're writing a controller, here are a few observations / comments:
  • please realise that you have ROS messaging between your node and the driver (I assume you implemented your controller in a node, as you mention the joint_group_vel_controller), this will increase jitter, depending on system and networking load
  • (time)synchronising a node and another node is non-trivial: how have you implemented this? Are you closing the loop using the /joint_states topic?
  • as you mention "I want to use my own optimal controller to send joint velocity commands to the UR10", I would actually recommend implementing your controller as a ros_control controller, instead of a separate node. That would remove jitter due to messaging and scheduling, and would run your controller at the exact frequency needed for your robot with minimal delay and jitter.
Finally: I'll repeat the recommendation @Rufus posted: if you haven't yet, please build and use a real-time capable kernel. Smooth control requires low-latency and minimum jitter, which a regular kernel will most likely not be able to support.
Edit:
I thought the PREEMPT_RT patched kernel was only needed for the the UR E-series? I'm working with a CB series.
A real-time kernel improves determinism, and the driver can use this to avoid unwanted delays.
As control laws are time-sensitive, especially to jitter, and you are (trying to) implement a form of real-time feedback control, reducing jitter and delays seems like it would be worthwhile. The increased rates of the e-Series definitely make running a real-time kernel more of a necessity, but even at 125 Hz, a real-time kernel will help.
Yes, I am using closed loop control, and reading the joints states from the topic mentioned above.
So that introduces additional messaging.
I would actually recommend implementing your controller as a ros_control controller, instead of a separate node. That would remove jitter due to messaging and scheduling, and would run your controller at the exact frequency needed for your robot with minimal delay and jitter."
Is there an example of adding custome controller ros control to serve as a baseline?
The sources for all of the controllers in ros_control are available over at ros-controls/ros_controllers. There is no difference between a "custom controller" or any of the already available ones.
Originally posted by gvdhoorn with karma: 86574 on 2021-01-13
Comment by StewartHemm74 on 2021-01-13:
Thanks for responding,
I thought the PREEMPT_RT patched kernel was only needed for the UR E-series? Is there a guide for installing the real time kernels on a Linux machine? I've used the ReadMe from the UR_ROS, and that installation process causes my monitor to display large icons. I'm working with a CB series. Yes, I am using closed loop control, and reading the joints states from the topic mentioned above.
Comment by gvdhoorn on 2021-01-13:\
this seems like it would be a different question.
I'd suggest posting an issue on the UR tracker if you have problems doing this. But it sounds like a problem with system configuration, not with anything UR specific, so perhaps a forum like Ask Ubuntu would be more appropriate.
Thank you!
Try running with PREEMPT_RT patched kernel
Realtime-enabled communication structure to robustly cope with the 2ms cycle time of the e-Series. To use this, compile and run it on a kernel with the PREEMPT_RT patch enabled. (See the Real-time setup guide on how to achieve this)
From https://github.com/UniversalRobots/Universal_Robots_ROS_Driver#features
Originally posted by Rufus with karma: 1083 on 2021-01-12
I thought the patched kernel was only needed for running a program on the UR-Eseries. Is it necessary for the CB series? Also, how do I know which kernel is necessary on my Linux machine? I've never installed the RT kernels successfully on a machine, most of the time the kernel causes weird display issues on my monitors.
