I am trying to control KUKA KR10 using MOVEIT. I am now able to control the joints using rqt_joint_trajectory controller. Now I want to send the robot in random position, using Rviz and moveit, and have Gazebo simulation of the robot follow the same path too. I have a controller named arm_position_controller in namespace kuka_kr10. I put them in this namespace, because I could not simulate the robot in Gazebo without it.
However, I cannot control the Robot using rviz only. My guess is, this is because rviz is publishing joint_state to namespace "kr10/joint_state" while the robot waits for messages on "joint_state". I do not know, if this assumption is correct, because when i manually change the joint state using rqt_joint_trajectory_controller, the change is reflected on rviz(however not in gazebo). Now my idea was to simply remap "kr10/joint_state" to "joint_state" and hope it works. Apparently it is not that easy. Does anyone have an idea, how do I go on about doing this?
I found this thread on how to achieve it using EKI but I am using RSI and the second answer mentions robtot_interface_streaming.launch which is not to be found in KUKA Industrial Package. Is there any easy way to do this?
Originally posted by brahpra on ROS Answers with karma: 36 on 2021-01-12
Comment by PRA008 on 2022-06-17:
Now can you follow this thread using rsi? I'm trying to do it, but I'm wondering.
I managed to solve it following this thread. robot_interface_streaming.launch can be found here. This Discussion helped me troubleshoot the fact, that I was unable to control my robot using rqt_joint_trajectory_controller. If anyone encounters the same problem, feel free to leave a comment. I guess, I kinda understand what was going on now.
Originally posted by brahpra with karma: 36 on 2021-01-13
Comment by Ranjit Kathiriya on 2021-03-25:
Hello @brahpra,
I am facing the same issue. Can you help me to resolve the Kuka issue? I am using Kuka RSI.
