Hi everyone.
I faced a problem that fail building rclpy from source.
I followed a official guide in this repository, but falied building during colcon build with a log below.
Starting >>> rclpy
--- stderr: rclpy
In file included from /home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/_rclpy.c:59:
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/./_rclpy_qos_event.c:23:3: error: unknown type name ‘rmw_message_lost_status_t’
   23 |   rmw_message_lost_status_t message_lost;
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/./_rclpy_qos_event.c: In function ‘_message_lost_to_py_object’:
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/./_rclpy_qos_event.c:171:3: error: unknown type name ‘rmw_message_lost_status_t’; did you mean ‘rmw_liveliness_lost_status_t’?
  171 |   rmw_message_lost_status_t * actual_data = &data->message_lost;
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/./_rclpy_qos_event.c:174:16: error: request for member ‘total_count’ in something not a structure or union
  174 |     actual_data->total_count,
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/./_rclpy_qos_event.c:175:16: error: request for member ‘total_count_change’ in something not a structure or union
  175 |     actual_data->total_count_change);
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/./_rclpy_qos_event.c: In function ‘_get_qos_event_data_filler_function_for’:
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/./_rclpy_qos_event.c:254:12: error: ‘RCL_SUBSCRIPTION_MESSAGE_LOST’ undeclared (first use in this function)
  254 |       case RCL_SUBSCRIPTION_MESSAGE_LOST:
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/./_rclpy_qos_event.c:254:12: note: each undeclared identifier is reported only once for each function it appears in
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/_rclpy.c: In function ‘rclpy_init’:
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/_rclpy.c:625:13: warning: implicit declaration of function ‘rcl_init_options_set_domain_id’; did you mean ‘rcl_init_options_get_allocator’? [-Wimplicit-function-declaration]
  625 |       ret = rcl_init_options_set_domain_id(&init_options, (size_t)domain_id);
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/_rclpy.c: In function ‘rclpy_resolve_name’:
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/_rclpy.c:1730:19: warning: implicit declaration of function ‘rcl_node_resolve_name’; did you mean ‘rclpy_resolve_name’? [-Wimplicit-function-declaration]
 1730 |   rcl_ret_t ret = rcl_node_resolve_name(
      |                   rclpy_resolve_name
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/_rclpy.c: In function ‘rclpy_context_get_domain_id’:
/home/ksato/dev/ros2/rclpy_ws/src/rclpy/rclpy/src/rclpy/_rclpy.c:5634:19: warning: implicit declaration of function ‘rcl_context_get_domain_id’; did you mean ‘rclpy_context_get_domain_id’? [-Wimplicit-function-declaration]
 5634 |   rcl_ret_t ret = rcl_context_get_domain_id(context, &domain_id);
make[2]: *** [CMakeFiles/rclpy.dir/build.make:63: CMakeFiles/rclpy.dir/src/rclpy/_rclpy.c.o] エラー 1
make[2]: *** 未完了のジョブを待っています....
make[1]: *** [CMakeFiles/Makefile2:140: CMakeFiles/rclpy.dir/all] エラー 2
make[1]: *** 未完了のジョブを待っています....
make: *** [Makefile:141: all] エラー 2
Failed   <<< rclpy [23.5s, exited with code 2]
Summary: 0 packages finished [23.6s]
  1 package failed: rclpy
  1 package had stderr output: rclpy
What is the cause?
Originally posted by ksato-dev on ROS Answers with karma: 83 on 2021-01-06
Mostly likely you're building the master branch against a released version of ROS. When building from master, you must build all packages from their latest development branch too. See this page for a guide:
https://index.ros.org/doc/ros2/Installation/Rolling/Linux-Development-Setup/#linux-latest
If you would like to build rclpy against the version of ROS you're using, checkout the appropriate branch. The rclpy repo has branches called dashing, eloquent, and foxy.
example for ROS Dashing:
cd rclpy
git checkout dashing
Originally posted by sloretz with karma: 3061 on 2021-01-06
Comment by ksato-dev on 2021-01-07:
Thanks! Probably, a problem in my case is this.
