I'm trying to fix Jenkins devel job of the package z_laser_projector
I'm having some import errors when running tests ("1.3. run tests" Console Section)
ModuleNotFoundError: No module named 'rospkg'
The whole package is developed for python3 in ROS melodic but Jenkins is using python2. I would like to ask if there is any way to force Jenkins configuration in order to run catkin with python3, for example forcing env vars as ROS_PYTHON_VERSION. Or am I missing something on package.xml?
Check that the build succeeds by running tests on TravisCI
Originally posted by rluque on ROS Answers with karma: 20 on 2020-12-23
The whole package is developed for python3 in ROS melodic [..]
ROS Melodic is Python 2 based. All packages released through the ROS buildfarm will therefore only get to use Python 2.
but Jenkins is using python2. [..] is there any way to force Jenkins configuration in order to run catkin with python3, for example forcing env vars as ROS_PYTHON_VERSION.
This is not a limitation of the ROS buildfarm, but of ROS Melodic (see also REP 3: Melodic Morenia).
No. The reason this is not working is because you cannot release a Python 3 package into ROS Melodic.
Or at least, not without some tricks (such as catkin_virtualenv).
For native Python 3 support, you'll have to switch to ROS Noetic (and/r ROS 2).
Yes, probably because you invoke the build of your workspace like this:
catkin_make -DPYTHON_EXECUTABLE=/usr/bin/python3 -DPYTHON_VERSION=3.6 --force-cmake
which forces the use of Python 3 in a ROS Melodic workspace (ie: a Python 2-based ROS distro).
Originally posted by gvdhoorn with karma: 86574 on 2020-12-23
Comment by rluque on 2021-01-11:
Thank you very much for your answer, it has been very helpful!
Melodic is configured as a Python 2 distribution. The default source-build configuration also uses Python 2 and changing that for a single package wouldn't work. You would need to add a separate binary distribution of Melodic using Python 3.
Originally posted by nuclearsandwich with karma: 906 on 2020-12-23
