I'm building a quadcopter and have discovered that most ESC have a built-in BEC, but I was wondering if it wouldn't be better to use only one.
What if I delivered power to my four ESC with a unique BEC ? Would that work ? I think this would be easier to configure (you have to set it up only once for the four ESC) and it would prevent each ESC from having it's own behavior.
Am I doing it wrong ?
Here is an image of what I'm talking about :
Edit : trying to find the original image and upload it.
Given the answer by Ian McMahon it appears that this schema is not the right thing to do, since I had misunderstood the role of BECs.
So would the right schema would look like this ? Edit : trying to find the original image and upload it. I'm still not sure if I'm getting it.
Do I need 4 ESCs with integrated BECs and connect all three cables to flight controller ?
11
  • $\begingroup$ So the right schema would look like this ? I'm still not sure if I'm getting it. Do I need 4 ESCs with integrated BECs and connect all three cables to flight controller ? <img src="http://img43.imageshack.us/img43/6963/escbec2.png"> $\endgroup$
    – mimipc
    Commented Feb 25, 2013 at 14:55
  • $\begingroup$ This is what I was suggesting, yes. In this case, only the "west" ESC is supplying power to the controller. You could certainly choose an ESC with integrated BEC for the "west" controller, but not for the other three, but likely you'll want to make sure they're all the same, because different ESCs may work slightly (or significantly) differently, which could be a challenge for your quadrotor :) $\endgroup$ Commented Feb 25, 2013 at 15:54
  • $\begingroup$ I'm also thinking about taking 4 ESCs without integrated BECs plus one standalone BEC. Could this possibly work ? $\endgroup$
    – mimipc
    Commented Feb 25, 2013 at 16:07
  • $\begingroup$ Yep, absolutely. In that case, you'd feed the BEC off the battery, same as the ESCs, and then run the flight controller off the BEC's output. All a BEC is is a little switching regulator that'll take some range of input (probably something like 7-12V) and put out regulated 5V (or 6V, some of them are switchable because some servos like 6V). I've built a couple of these, I'll put some details up in my answer (where I can embed images) $\endgroup$ Commented Feb 25, 2013 at 16:12
  • $\begingroup$ Thanks again, I really apreciate your comments. So the programmable part (cutoff, brakes, soft start, etc.) is handled by the ESCs ? I thought it was the BEC ! $\endgroup$
    – mimipc
    Commented Feb 25, 2013 at 16:14
Typically you want to power the ESCs directly from the battery, and use a BEC to power 5v electronics such as your controller. However, a lot of ESCs have the ability to provide 5v power back to the controller over the 5v line on their control cable (servo-style 3 pin cable). In that case, you wouldn't need to use a BEC at all, but it's possible you might have issues with more than one ESC all trying to supply power on the 5v line with them all hooked together. For maximum flexibility, it might make sense to select an ESC which has switchable BEC capability.
My project experience (since removed) can be found in an earlier revision of this answer.
5
  • $\begingroup$ Thanks for your answer. I was completely wrong regarding the usage of BECs. That's why many people cut the red wire on all but one ESCs. This powers the flight controller and it only needs ground and control lines to send data back. Right ? $\endgroup$
    – mimipc
    Commented Feb 25, 2013 at 14:46
  • $\begingroup$ Exactly. If you were to cut the red wire on three of the four ESCs, and let the fourth one power your controller, you should be good to go. Now, if you need more current than one ESC can supply, you may need to rethink this, but you probably won't. They're designed to power a receiver and a bunch of servos, and servos likely consume much more power than your controller will. $\endgroup$ Commented Feb 25, 2013 at 14:48
  • $\begingroup$ @IanMcMahon - What is the relevance of your pictures to your answer? $\endgroup$
    – Mark Booth
    Commented Feb 26, 2013 at 12:54
  • $\begingroup$ @IanMcMahon - Comments are intended to help improve the quality of an answer (or question) rather than responding to a comment like this with another comment, it is better to edit your answer, that way the comment can be tidied up (deleted) and it will no longer distract readers from the answer itself. $\endgroup$
    – Mark Booth
    Commented Feb 26, 2013 at 13:02
  • $\begingroup$ Hi @IanMcMahon, you didn't need to remove the video links, I just thought it would be nice if you could mention why you thought they were relevant. Your answer is probably better without them, but I have added a link so that people can get to them easily if they are interested. I still think that you should fold the info in your 14:48 comment into the answer though, it would improve your answer and help tidy thing up the comments. $\endgroup$
    – Mark Booth
    Commented Aug 25, 2015 at 13:38
