This is the first time I'm using an IMU (Bosch BNO055) on a mobile base. The IMU provides absolute orientation, angular velocity and angular acceleration. I'm planning to use the robot_localization package to fuse this data with wheel encoder data. Even though I did a bunch of searching and reading, I'm still not clear to which extent the position of the IMU on my mobile base can be accounted for. I know that angular velocity and acceleration will differ from the actual values of the base if the IMU is not aligned with the movement axis of the base. Is there a simple way to calculate the actual values if, for example, I were to place the IMU in the right front corner of my mobile base as opposed to the center?
Originally posted by west2788 on ROS Answers with karma: 3 on 2020-12-13
