http://data.selfracingcars.com/
I was using RTABMAP before since I wanted to be able to differentiate between the green patch of grass and the actual track (which Lidar wouldn't be able to do as it won't hit anything). But it doesn't look like it does that. Was wondering if there was a more appropriate package that makes use of any of the map data from that website.
Edit: Here are examples of some of the races for this track: https://youtu.be/KmOakRbBGFM, https://youtu.be/Z6Hc2aD7tJQ
Originally posted by sisaha9 on ROS Answers with karma: 90 on 2020-11-22
Hi,
If you want to play PCAP data on ROS, see this page: https://dominoc925.blogspot.com/2019/05/displaying-velodyne-pcap-data-in-ros.html
For an example with RTAB-Map (>=0.20.7 built with libpointmatcher support), based on this ouster example, you can try the following:
  1. Play a PCAP (I tried the 1.4 GB one):
    roslaunch velodyne_pointcloud 32e_points.launch pcap:=$HOME/Downloads/velodyne/2016-05-28hdl32.pcap read_once:=true rpm:=1200
  2. Add a base_link to make x-axis of the car forward (lidar is looking right)
    rosrun tf static_transform_publisher 0 0 0 -1.570796327 0 0 base_link velodyne 100
  3. Start mapping:
    roslaunch rtabmap_ros rtabmap.launch
    use_sim_time:=false
    depth:=false
    subscribe_scan_cloud:=true
    frame_id:=base_link
    scan_cloud_topic:=/velodyne_points
    scan_topic:=/disabled
    scan_cloud_max_points:=34750
    scan_cloud_assembling:=true
    scan_cloud_assembling_time:=0.5
    scan_cloud_assembling_voxel_size:=0.5
    icp_odometry:=true
    approx_sync:=false
    args:="-d
    --RGBD/CreateOccupancyGrid false
    --RGBD/ProximityMaxGraphDepth 0
    --RGBD/ProximityPathMaxNeighbors 5
    --RGBD/LocalRadius 30
    --RGBD/ProximityMaxPaths 1
    --Rtabmap/DetectionRate 0
    --Icp/PM true
    --Icp/VoxelSize 0.5
    --Icp/MaxTranslation 10
    --Icp/MaxCorrespondenceDistance 1.5
    --Icp/PMOutlierRatio 0.7
    --Icp/Iterations 30
    --Icp/PointToPlane true
    --Icp/PMMatcherKnn 3
    --Icp/PMMatcherEpsilon 1
    --Icp/PMMatcherIntensity true
    --Icp/Epsilon 0.0001
    --Icp/PointToPlaneK 10
    --Icp/PointToPlaneRadius 0
    --Icp/CorrespondenceRatio 0.2
    --Icp/PointToPlaneGroundNormalsUp 0.8
    --Icp/PointToPlaneMinComplexity 0.0"
    odom_args:="
    --Odom/ScanKeyFrameThr 0.7
    --OdomF2M/ScanMaxSize 10000
    --OdomF2M/ScanSubtractRadius 0.5
    --Icp/Iterations 10
    --Icp/CorrespondenceRatio 0.01
    --Icp/MaxTranslation 2
    --Icp/PMOutlierRatio 0.4
    --Icp/PointToPlane false"
Here are some results: image description
Colored with intensity from LiDAR:
image description
LiDAR Odometry-only (red lines are loop closures):
image description
With loop closure optimization:
image description
To distinguish the track and the grass, the velodyne's intensity channel can give a good idea. We can see it more clearly in this video: https://youtu.be/hmtdcxV-0NU
The parameters above are quite very for this dataset to close the loops without a camera. Combining with a stereo camera could help to detect loop closures more robustly.
EDIT
Integrating a stereo camera is possible (assuming it is already calibrated, synchronized between left and right cameras and provide common stereo topics). You could add to rtabmap.launch command above:
stereo:=true \
rgbd_sync:=true \
approx_sync:=true \
approx_rgbd_sync:=false \
left_image_topic:=/stereo_camera/left/image_rect \
right_image_topic:=/stereo_camera/right/image_rect \
left_camera_info_topic:=/stereo_camera/left/camera_info \
right_camera_info_topic:=/stereo_camera/right/camera_info
This will synchronize stereo data with Lidar data. You may also do stereo visual odometry instead of LiDAR odometry, I think it would be a little more robust because of the lack of geometry in this kind of environment. To use stereo odometry, remove icp_odometry:=true above and set back --Rtabmap/DetectionRate 2. As I did for Lidar, there could be some tunings for visual parameters depending on the resolution of the cameras and this kind of environment. If you want to use external odometry from another visual odometry package, add:
visual_odometry:=false \
odom_topic:=/my_visual_odometry_topic
Originally posted by matlabbe with karma: 6409 on 2020-11-28
Post score: 5
Comment by sisaha9 on 2020-11-29:
Wow that is amazing. I didn't think the Lidar information could actually be useful like that. How do you recommend combining it with a stereo camera? Like would RTABMAP do it automatically or would I have to change a parameter
Comment by matlabbe on 2020-11-29:
I edited the answer :)
Thanks! Just curious but this is likely not possible if we use a 2D Lidar right. The intensity channels and stuff come from the fact that the Velodyne Lidar is a 3D Lidar. So we would have to rely more on a stereo map or is there a way to use this 3D data with a 2D Lidar?
With a 2D lidar tilted, it could be possible along with stereo odometry to assemble them in 3D. Some 2D lidars (like SICK) have also an intensity (or reflectivity) channel.
Comment by sisaha9 on 2020-12-01:
I have a Intel Realsense D455 camera. Was wondering if it was possible to use this data but by converting the depthscans of the Realsense to Laserscans to follow this data
Comment by matlabbe on 2020-12-10:
No, use rtabmap as stereo slam directly (or rgb-d slam when using depth image from the camera). Those parameters are really tuned for ring-like lidars like velodyne or ouster.
