I am trying to launch a world file using roslaunch and running into errors. I am working with ROS kinetic and gazebo-7. My ultimate goal is to open a custom world made with the world plugin, and spawn a urdf into that world.
I have been using roslaunch to start an empty world with the following launch file, and that has worked fine.
<?xml version="1.0" encoding="UTF-8"?>
<launch>
    <include file="$(find gazebo_ros)/launch/empty_world.launch">
    </include>
</launch>
However, when I try to use the examples found in the Gazebo Ros tutorials to launch another world file, the execution fails.
Example:
<launch>
        <arg name="world_name" value="mud.world"/>
        <arg name="debug" value="true"/>
    </include>
</launch>
Results in the error below:
   terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::lock_error> >'
  what():  boost: mutex lock failed in pthread_mutex_lock: Invalid argument
terminate called recursively
Thread 18 "gzserver" received signal SIGABRT, Aborted.
The result is that the gazebo window opens but never loads any world, it simply stays at a black screen.
Note: I have already put the gazebo worlds directory in my .bashrc and I have tried apt-get update and apt-get upgrade.
Originally posted by rmmilner on ROS Answers with karma: 11 on 2020-11-18
Comment by 130s on 2020-11-19:
By no means this will be a "solution", but a potential workaround https://answers.gazebosim.org/question/15138/need-help-with-error-when-launch-gazebo-first-time/
Solution was a simple syntax error:
<launch>
    <arg name="world_name" value="worlds/mud.world"/>
  </include>
</launch>
Originally posted by rmmilner with karma: 11 on 2020-11-19
