I run my code flawlessly in ROS Melodic but in ROS Noetic, I am having the following error (maybe because of python3):
  File "/opt/ros/noetic/lib/rqt_gui/rqt_gui", line 13, in <module>
    sys.exit(main.main())
  File "/opt/ros/noetic/lib/python3/dist-packages/rqt_gui/main.py", line 61, in main
    return super(
  File "/opt/ros/noetic/lib/python3/dist-packages/qt_gui/main.py", line 614, in main
    perspective_manager.import_perspective_from_file(
  File "/opt/ros/noetic/lib/python3/dist-packages/qt_gui/perspective_manager.py", line 360, in import_perspective_from_file
    self._convert_values(data, self._import_value)
  File "/opt/ros/noetic/lib/python3/dist-packages/qt_gui/perspective_manager.py", line 422, in _convert_values
    self._convert_values(groups[group], convert_function)
  [Previous line repeated 1 more time]
  File "/opt/ros/noetic/lib/python3/dist-packages/qt_gui/perspective_manager.py", line 419, in _convert_values
    keys[key] = convert_function(keys[key])
  File "/opt/ros/noetic/lib/python3/dist-packages/qt_gui/perspective_manager.py", line 429, in _import_value
    return QByteArray.fromHex(eval(value['repr(QByteArray.hex)']))
  File "<string>", line 1, in <module>
TypeError: arguments did not match any overloaded call:
  QByteArray(): too many arguments
  QByteArray(int, str): argument 1 has unexpected type 'str'
  QByteArray(Union[QByteArray, bytes, bytearray]): argument 1 has unexpected type 'str'
Any idea on this? Or have you encountered this before?
Thanks
Originally posted by abata on ROS Answers with karma: 33 on 2020-11-10
Comment by mikessut on 2020-11-11:
I'm hitting exact same error with rqt. I'm able to get it to run by changing /opt/ros/noetic/lib/python3/dist-packages/qt_gui/perspective_manager.py:429 to return value['repr(QByteArray.hex)']. Still get a bunch of errors, but it at least runs.
Comment by abata on 2020-11-11:
My launch file was using a .perspective file. Also, when I tried to load it manually in rqt. The same errors happened. It was not necessary for me to load that file, then I modified the launch file :)
Hey, I also encountered the same problem when porting some existing code to the ROS noetic.
In my case I had a launch file which invoked rqt_gui with a so-called perspective file, like this:
<node name="rqt_gui" pkg="rqt_gui"
type="rqt_gui" respawn="false"
args="--perspective-file $(find cyton_gamma_300_gazebo)/config/gazebo_effort_controller.perspective"/>
The perspective file in turn looked similar to the following:
    ..., "mainwindow": {
  "keys": {
    "geometry": {
      "type": "repr(QByteArray.hex)",
      "repr(QByteArray.hex)": "QtCore.QByteArray('01d9d')",
      "pretty-print": "     :     I :     I     "
    "state": {
      "repr(QByteArray.hex)": "QtCore.QByteArray('000000ff')",
      "pretty-print": "                 Lrqt_topic__TopicPlugin__1__TopicWidget          Xrqt_publisher__Publisher__1__PublisherWidget                            6MinimizedDockWidgetsToolbar        "
We are interested in the key-value pairs looking similar to the following:
and change it to the following:
"repr(QByteArray.hex)": "b'000000ff'",
I.e. after replacing the value with only byte content, like b'000000ff' and removing QtCore.QByteArray() creation, the rqt_gui is able to start without errors. No patching of noetic code required. Hope this helps!
Originally posted by selyunin with karma: 96 on 2021-01-06
Post score: 7
Comment by M Usamah Shahid on 2021-01-29:
This worked perfectly for me. Thanks a lot
