Hello guys
I have already read through several threads like this but couldn't figure out what my issue is..
I have a robot and a remote PC. I want to visualize the lidar data of the robot in rviz on my remote PC. Now my problem is that I can see with 'rostopic list' the topic /scan but when I try 'rostopic echo /scan' on my remote PC nothing is published. When I try 'rostopic echo /scan' on the robot I can see the data - so it definetly should work!
When I tried roswtf it tells me: ERROR Could not contact the following nodes:
  • /hlds_laser_publisher
ERROR The following nodes should be connected but aren't:
  • /hlds_laser_publisher->/rviz_1602065662574712563 (/scan)
  • /hlds_laser_publisher->/rosout (/rosout)
ERROR Errors connecting to the following services:
  • service [/hlds_laser_publisher/get_loggers] appears to be malfunctioning: Unable to communicate with service [/hlds_laser_publisher/get_loggers], address [rosrpc://robot:53743]
  • service [/hlds_laser_publisher/set_logger_level] appears to be malfunctioning: Unable to communicate with service [/hlds_laser_publisher/set_logger_level], address [rosrpc://robot:53743]
Both are connected to the same network and can ping each other. Master is my remote PC -> bashrc network configuration is like the following:
remotePC: export ROS_MASTER_URI=http://remotePC:11311 export ROS_HOSTNAME=remotePC
robot: export ROS_MASTER_URI=http://remotePC:11311 export ROS_HOSTNAME=robot
I have added the IPs of robot and remotePCo /etc/hosts
I hope somebody can help me with this network configuration issue..
Originally posted by lslabon on ROS Answers with karma: 23 on 2020-10-07
Comment by Solrac3589 on 2020-10-07:
checking here (http://wiki.ros.org/ROS/Tutorials/MultipleMachines, at the end) Seems like could be that you forgot to define ROS_IP
Comment by lslabon on 2020-10-08:
You can define ROS_IP either with export ROS_IP or with export ROS_HOSTNAME
Assume robot IP is = 192.168.1.10 and remote PC IP is 192.168.1.20
On the robot (the ROS master) run the following commands and then run roscore and any ros node
source /opt/ros/melodic/setup.bash
export ROS_MASTER_URI=http://192.168.1.10:11311
export ROS_IP=192.168.1.10
On the remote PC, apply the following settings before running your application:
export ROS_IP=192.168.1.20
Then try to access robot topics on your remote PC.
Also
check your firewalls on both. You can disable your firewall for a quick test:
sudo ufw disable
Originally posted by afar with karma: 111 on 2020-10-07
Omg ! Can't believe it lol
It was the firewall. Thank you guys for your help !
