Hi I make a autonomous differential robot. In kinetic devel navigation stack works fine. Robot can get position, goes goal, escape obstacle....However i upgrade my linux and ros base to melodic devel.
In melodic devel i get the error. My robot doesn't avoid from obstacles.I cant solve this... Is there any solution?
Warning: Invalid argument "/laser" passed to canTransform argument source_frame in tf2 frame_ids cannot start with a '/' like: at line 134 in /tmp/binarydeb/ros-melodic-tf2-0.6.5/src/buffer_core.cpp [ERROR] [1601902625.778502017]: TF Exception that should never happen for sensor frame: , cloud frame: /laser, Invalid argument "/laser" passed to lookupTransform argument source_frame in tf2 frame_ids cannot start with a '/' like:
Originally posted by bfdmetu on ROS Answers with karma: 85 on 2020-10-05
I solved the problem. In laser scanner package, frame name is "/laser"... I ommit the "/" then it works
Originally posted by bfdmetu with karma: 85 on 2020-10-06
Comment by vvb on 2021-10-19:
I have the same issue. Could you please elaborate a little bit more on this. I get issues while I'm trying to run the TEB local planner.
