I have a ros node that needs to communicate with a non-ros over a tcp asynchronous socket connection. This node will be subscribed to a variety of topics and needs to send data over the socket connection when a message is received (by calling the socket writer within the subscriber callback).
My issue is that I cannot use async/await syntax for a subscriber callback since rospy.Subscriber()
does not allow the callback to be awaited.
Ubuntu20 Ros Noetic Python 3.8.2
Here's a MWE:
A generic publisher, representing one of several nodes generating data I eventually want to send over the socket:
#!/usr/bin/env python3
import rospy
def sample_publisher():
rospy.init_node('question_pub')
pub = rospy.Publisher('topic_name', String, queue_size=10)
rate = rospy.Rate(1)
msg = String(data="sample message")
rospy.loginfo("starting publish loop")
pub.publish(msg)
rospy.loginfo("finished pub'in")
rate.sleep()
if __name__ == '__main__':
sample_publisher()
The subscriber in question:
import rospy
import asyncio
class listener_handle:
def __init__(self):
rospy.init_node('question_sub')
self.server_address = '127.0.0.1'
self.port = 51222
def activate_subscribers(self):
#separated to ensure async writer is defined before first message
rospy.Subscriber("topic_name", String, self.callback)
async def connect2server(self):
self.reader, self.writer = await asyncio.open_connection(self.server_address, self.port)
async def async_spin(self):
rospy.loginfo("beginning node spin")
#want bidirectional messages
recvData = await self.reader.read(100)
rospy.loginfo("got {} from socket server".format(recvData.decode()))
async def callback(self, data):
rospy.loginfo("callback received value of {}".format(data.data))
self.writer.write(data.data.encode())
await self.writer.drain()
async def main():
h = listener_handle()
await h.connect2server()
h.activate_subscribers()
await h.async_spin()
asyncio.run(main())
which errors on startup with
/opt/ros/noetic/lib/python3/dist-packages/rospy/topics.py:750: RuntimeWarning: coroutine 'listener_handle.callback' was never awaited
cb(msg)
and, for reference, the socket server I'm trying to connect to:
import asyncio
async def handle_echo(reader, writer):
print("client connected, waiting for msg")
data = await reader.read(100)
message = data.decode()
print("Received {}".format(message))
writer.write(data)
#immediately send back to subscriber client
await writer.drain()
print("Close the connection")
writer.close()
async def main():
server = await asyncio.start_server(
handle_echo, '127.0.0.1', 51222)
print("server started up")
async with server:
await server.serve_forever()
asyncio.run(main())
I've attempted to make the subscriber asynchronous but it is not awaitable.
I know the subscribers themselves work asynchronously, but I looked for a few hours and was unable to find any examples using the asyncio library like this.
How can I use await within a rospy subscriber callback? Thanks in advance!
Originally posted by chives_onion on ROS Answers with karma: 180 on 2020-09-30
