Hello guys, can someone tell me why the map is not updating with respect to the displacement in base_link? The map keeps building at one place, whereas I can see the laser data moving wrt base_link, but the map doesn't move.
  1. launched the laser scan
  2. static tf between map and odom(slam is supposed to provide this, but I always get map frame not available)
3)Odom publisher
4)static tf between base_link and camera_link
5)then I launch the slam_gmapping.
https://drive.google.com/drive/folders/1b4HVWzpKfWp937sdIS8cLRbGr5eIMtLh?usp=sharing
Originally posted by Gourav on ROS Answers with karma: 3 on 2020-09-24
Comment by JackB on 2020-09-24:
Can you please add the pdf output of rosrun tf view_frames to that folder?
Comment by Gourav on 2020-09-24:
done.. I included that
Thanks for doing that!
A big red flag is that your map->odom transform is static. That is almost certainly the reason for the problem behavior. slam_gmapping is responsible for producing that. For some reason I don't understand, you said that you override the map->odom tf with a static transfrom publisher. Remove that and let gmapping publish the map->odom tf and then we should be on our way to fixing the problem.
Originally posted by JackB with karma: 977 on 2020-09-24
I agree with you, but I keep getting this error (https://answers.ros.org/question/361629/unable-to-create-map-using-gmapping-ros-melodic-on-jetson-nano/) if I don't do the map->odom static transform... I will try once more and will update. thanks for the reply :-)
Add a copy of rosrun tf view_frames pdf output without the static map->odom publisher please. Make sure gmapping is running.
Updated the file again.
its the same problem, btw I used the following files https://github.com/ros-perception/slam_gmapping
And when you rostopic echo /your/laser/scan/topic what is the frame_id in the header?
camera_depth_frame
And is this all in simulation on the same computer?
yes it is.
don't understand why the slam is not providing the transform between map and doom..
The only changes I made in this file (https://github.com/ros-perception/slam_gmapping) is .. ----to---- and changed the maxRange ..
