I ran this command to find out if my OpenCV version was 4:
kg-config --modversion opencv4
The outcome was:
4.2.0
I also tried importing it after calling python3 on the lxterminal, verifying that the version I'm using is 4.
My ROS distro is Noetic, would that version of OpenCV work here? Should I install OpenCV2? If the answer is affirmative, would that cause any conflict of interest with OpenCV4?
Thanks in advance for any input.
Originally posted by ajpaezm on ROS Answers with karma: 3 on 2020-09-23
Comment by Solrac3589 on 2020-09-24:
i could guess between opencv3 and opencv4, but opencv2 i think is so old, isn't?
from http://wiki.ros.org/vision_opencv Seems like the standard is opencv3 (at the end it says that). In melodic i had issues with 4.2 but nevertheless is possible to work with 4.2 if you search through internet, and personally seems to be much better in performance the 4.2, so, up to you
There is only a one version for which Noetic binary packages are built on Ubuntu Focal (20.04): that would be version 4.2.
Refer to REP 3 - Target Platforms: Noetic Ninjemys (May 2020 - May 2025) for information on which specific versions of the various dependencies are supported.
Technically vision_opencv should support the range of versions listed in the row for OpenCV (so 3.2 and 4.2).
Originally posted by gvdhoorn with karma: 86574 on 2020-09-24
Comment by ajpaezm on 2020-09-24:
Got it, thanks a lot.
Something else @gvdhoorn:
In my CMakeLists.txt file, I have the following line:
find_package(OpenCV REQUIRED)
Should I change that in order to point out the proper OpencV version?
