I am trying to subscribe to two topics. If their header stamps are equal they should be combined into a single message and published.
I believe that an exact_time message_filter is the way to go here.
In my case the messages will be high resolution images so would like the node to be written in C++ to reduce the CPU cost.
For testing I have wrote up a Python node to to publish two messages (just sensor_msgs::msg::Temperature for this testing case) with the same header stamp. This node works with no issue.
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import Temperature
class DoublePublisher(Node):
    def __init__(self):
        super().__init__('double_publisher')
        # create publishers
        self.publisher_temp_1_ = self.create_publisher(Temperature, 'temp_1', 10)
        self.publisher_temp_2_ = self.create_publisher(Temperature, 'temp_2', 10)
        # create timer
        timer_period = 1
        self.timer_ = self.create_timer(timer_period, self.timer_callback)
        # initialize counter
        self.i = 0
    def timer_callback(self):
        self.get_logger().info("Publishing messages")
        # get current time for headers
        msg_stamp = self._clock.now().to_msg()
        # create and publish Temperature messages
        msg_1 = Temperature()
        msg_1.header.stamp = msg_stamp
        msg_1.temperature = float(self.i)
        self.publisher_temp_1_.publish(msg_1)
        msg_2 = Temperature()
        msg_2.header.stamp = msg_stamp
        msg_2.temperature = float(self.i + 2)
        self.publisher_temp_2_.publish(msg_2)
        self.i += 1
def main(args=None):
    rclpy.init(args=args)
    minimal_publisher = DoublePublisher()
    rclpy.spin(minimal_publisher)
    minimal_publisher.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
    main()
I then tried to make a C++ node that would use message filters to subscribe to the two topics and call a callback if two messages have the same timestamp. I can't really find any solid examples on how to do this in ROS2. I tried to figure it out from the comments in the code from this repo. Below is my code and the compile errors that I get.
The code:
#include <memory>
#include <string>
#include <cstring>
#include "rclcpp/rclcpp.hpp"
#include "std_msgs/msg/string.hpp"
#include "sensor_msgs/msg/temperature.hpp"
#include "message_filters/subscriber.h"
#include "message_filters/time_synchronizer.h"
using std::placeholders::_1;
using std::placeholders::_2;
class ExactTimeSubscriber : public rclcpp::Node
public:
  ExactTimeSubscriber()
      : Node("exact_time_subscriber")
    subscription_temp_1_.subscribe(this, "temp_1");
    subscription_temp_2_.subscribe(this, "temp_2");
    message_filters::TimeSynchronizer<sensor_msgs::msg::Temperature, sensor_msgs::msg::Temperature> sync_(subscription_temp_1_, subscription_temp_2_, 3);
    sync_.registerCallback(std::bind(&ExactTimeSubscriber::topic_callback, this, _1, _2));
private:
  void topic_callback(const sensor_msgs::msg::Temperature::SharedPtr tmp_1, const sensor_msgs::msg::Temperature::SharedPtr tmp_2) const
    const char *temp_1 = std::to_string(tmp_1->temperature).c_str();
    const char *temp_2 = std::to_string(tmp_2->temperature).c_str();
    RCLCPP_INFO(this->get_logger(), "I heard: '%s' and '%s'", temp_1, temp_2);
  message_filters::Subscriber<sensor_msgs::msg::Temperature> subscription_temp_1_;
  message_filters::Subscriber<sensor_msgs::msg::Temperature> subscription_temp_2_;
int main(int argc, char *argv[])
  rclcpp::init(argc, argv);
  rclcpp::spin(std::make_shared<ExactTimeSubscriber>());
  rclcpp::shutdown();
  return 0;
Does anyone know how to use the message_filters::TimeSynchronizer (or similar) to synchronize messages in ROS2?
My system details are as follows:
  • X86 64 CPU architecture
  • Ubuntu 18.04.5
  • Eloquent
My compile error follows:
This code block was moved to the following github gist: https://gist.github.com/answers-se-migration-openrobotics/51c9b332b630e16531e063dce57eec20
Originally posted by srubs_r on ROS Answers with karma: 13 on 2020-09-15
Your callback has the wrong signature. The message filter callback must take in a reference to a const std::shared_ptr<const...>&, whereas you have just a const std::shared_ptr<> Change your callback declaration line to this:
  const sensor_msgs::msg::Temperature::ConstSharedPtr& tmp_1,
  const sensor_msgs::msg::Temperature::ConstSharedPtr& tmp_2) const
Then it will compile.
Originally posted by Geoff with karma: 4203 on 2020-09-15
Comment by sttobia on 2020-11-27:
Thanks for the answer, this helped me to get started with the package and compile a similar minimal example like the one above. However, this example still does not work as expected for me in ROS2 on ubuntu. Somehow, the callback function is never reached even though I can check that the messages that reach the subscribers themselves have the exact same timestamp. This might be a problem with the message_filters package itself I fear. I posted a question about this which is awaiting moderation here:
https://answers.ros.org/question/366440/ros-2-message_filters-timesynchronizer-minimal-example-does-not-reach-callback-function/
I would be happy if you could verify that I am not a bot and make the question open for the public and maybe also help me with it by quickly reproducing the issue.
Even after changing the callback's arguments to const sensor_msgs::msg::Temperature::ConstSharedPtr&, your subscription node won't work. You declare sync_ as a local variable in ExactTimeSubscriber's constructor, but sync_ should be declared as a member variable of ExactTimeSubscriber', otherwise it goes out-of-scope.
The following works.
#include <memory>
#include <string>
#include <cstring>
public:
    sync_ = std::make_shared<message_filters::TimeSynchronizer<sensor_msgs::msg::Temperature, sensor_msgs::msg::Temperature>>(subscription_temp_1_, subscription_temp_2_, 3);
    sync_->registerCallback(std::bind(&ExactTimeSubscriber::topic_callback, this, _1, _2));
private:
  void topic_callback(const sensor_msgs::msg::Temperature::ConstSharedPtr& tmp_1, const sensor_msgs::msg::Temperature::ConstSharedPtr& tmp_2) const
  std::shared_ptr<message_filters::TimeSynchronizer<sensor_msgs::msg::Temperature, sensor_msgs::msg::Temperature>> sync_;
  rclcpp::shutdown();
  return 0;
Originally posted by kas with karma: 66 on 2021-04-07
