How do I publish a message from a file, found with rospack find, using rostopic pub -f from a launch file?
<node pkg="rostopic" type="rostopic" name="arbitrary_node_name" args="pub topic_name msg_type -l -f $(find package_name)/message_details.yaml" output="screen" />
doesn't publish anything.
Originally posted by noob_ros on ROS Answers with karma: 21 on 2020-08-29
Comment by noob_ros on 2020-08-31:
Correction: message is published but only partially (message_details specifies several ros messages separated by '---' but only first message is published)
it seems things are actually working as they should.
According to the wiki page (emphasis mine):
-f FILE
Read message fields from YAML file. YAML syntax is equivalent to output of rostopic echo. Messages are separated using YAML document separator ---. To use only the first message in a file, use the --latch option.
(this is the same info you'd get when running rostopic pub --help btw)
Note how it mentions the latch option and how that causes rostopic pub to only publish "the first message".
You have the -l command line option in your args attribute in the .launch file you show:
That would be the short version of --latch.
Originally posted by gvdhoorn with karma: 86574 on 2020-09-01
