Hello,
I'm currently working on a differential drive robot with ROS2 and encountering some errors with a rclcpp transform broadcaster. I hope i can get some answers as to what I am doing wrong. I'm using ROS2 dashing on ubuntu 18.04.
code:
#include <memory>
#include "rclcpp/rclcpp.hpp"
#include <tf2_ros/transform_broadcaster.h>
#include "nav_msgs/msg/odometry.hpp"
#include <geometry_msgs/msg/transform_stamped.h>
#include <tf2/LinearMath/Quaternion.h>
std::shared_ptr<rclcpp::Node> node = nullptr;
void topic_callback(const nav_msgs::msg::Odometry::SharedPtr msg){
static tf2_ros::TransformBroadcaster br;
geometry_msgs::msg::TransformStamped transformStamped;
transformStamped.header.stamp = rclcpp::Time();
transformStamped.header.frame_id = "odom";
transformStamped.child_frame_id = "base_link";
transformStamped.transform.translation.x = msg->pose.pose.position.x;
transformStamped.transform.translation.y = msg->pose.pose.position.y;
transformStamped.transform.translation.z = 0.0;
transformStamped.transform.rotation.x = 0.0;
transformStamped.transform.rotation.y = 0.0;
transformStamped.transform.rotation.z = msg->pose.pose.orientation.z;
transformStamped.transform.rotation.w = msg->pose.pose.orientation.w;
broadcaster.sendTransform(transformStamped);
int main(int argc, char * argv[])
rclcpp::init(argc, argv);
auto node = std::make_shared<rclcpp::Node>("tf_broadcaster");
auto subscriber = node->create_subscription<nav_msgs::msg::Odometry>("odom",10, &topic_callback);
rclcpp::spin(node);
rclcpp::shutdown();
return 0;
error message:
/home/frederik/ros2botpc/src/tfbroadcast/src/tfbroadcast.cpp: In function ‘void topic_callback(nav_msgs::msg::Odometry_<std::allocator<void> >::SharedPtr)’:
/home/frederik/ros2botpc/src/tfbroadcast/src/tfbroadcast.cpp:12:45: error: no matching function for call to ‘tf2_ros::TransformBroadcaster::TransformBroadcaster()’
In file included from /home/frederik/ros2botpc/src/tfbroadcast/src/tfbroadcast.cpp:4:0:
/opt/ros/eloquent/include/tf2_ros/transform_broadcaster.h:53:3: note: candidate: template<class NodeT, class AllocatorT> tf2_ros::TransformBroadcaster::TransformBroadcaster(NodeT&&, const rclcpp::QoS&, const rclcpp::PublisherOptionsWithAllocator<AllocatorT>&)
/opt/ros/eloquent/include/tf2_ros/transform_broadcaster.h:53:3: note: template argument deduction/substitution failed:
/home/frederik/ros2botpc/src/tfbroadcast/src/tfbroadcast.cpp:12:45: note: candidate expects 3 arguments, 0 provided
/opt/ros/eloquent/include/tf2_ros/transform_broadcaster.h:49:7: note: candidate: tf2_ros::TransformBroadcaster::TransformBroadcaster(const tf2_ros::TransformBroadcaster&)
class TransformBroadcaster{
/opt/ros/eloquent/include/tf2_ros/transform_broadcaster.h:49:7: note: candidate expects 1 argument, 0 provided
/opt/ros/eloquent/include/tf2_ros/transform_broadcaster.h:49:7: note: candidate: tf2_ros::TransformBroadcaster::TransformBroadcaster(tf2_ros::TransformBroadcaster&&)
/home/frederik/ros2botpc/src/tfbroadcast/src/tfbroadcast.cpp:24:8: error: ‘broadcaster’ was not declared in this scope
Originally posted by Loekes on ROS Answers with karma: 23 on 2020-08-28
Comment by surfertas on 2020-09-06:
Was this resolved?
