I'm new to ros, I exported urdf from solidworks. when I add transmission to urdf and launch it gazebo is not opening it's giving me error as
[ INFO] [1597656176.792430594, 0.245000000]: Loading gazebo_ros_control plugin
[ INFO] [1597656176.793072386, 0.245000000]: Starting gazebo_ros_control plugin in namespace: /
[ INFO] [1597656176.794135347, 0.245000000]: gazebo_ros_control plugin is waiting for model URDF in parameter [robot_description] on the ROS param server.
Segmentation fault (core dumped)
[gazebo-1] process has died [pid 16223, exit code 139, cmd /home/xxxxx/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/scripts/gzserver -e ode worlds/empty.world __name:=gazebo __log:=/home/xxxx/.ros/log/5c2a3c2a-e069-11ea-a169-28d2447fbe91/gazebo-1.log].
log file: /home/xxxxx/.ros/log/5c2a3c2a-e069-11ea-a169-28d2447fbe91/gazebo-1*.log
but if I launch removing transmission tags it's launch perfectly.
I also tried with rrbot it gives me same error
edit: I've noticed it's because of this
<gazebo>
<plugin name="gazebo_ros_control" filename="libgazebo_ros_control.so">
<robotNamespace>/</robotNamespace>
</plugin>
</gazebo>
edit 2:
urdf:
<?xml version="1.0" encoding="utf-8"?>
<!-- This URDF was automatically created by SolidWorks to URDF Exporter! Originally created by Stephen Brawner ([email protected])
Commit Version: 1.5.1-0-g916b5db Build Version: 1.5.7152.31018
For more information, please see http://wiki.ros.org/sw_urdf_exporter -->
<robot
name="myrobot">
<link
name="base_link">
<inertial>
<origin
xyz="-9.8696E-13 1.9623E-12 0.0045914"
rpy="0 0 0" />
<mass
value="0.42609" />
<inertia
ixx="0.00066906"
ixy="9.8933E-19"
ixz="-1.1435E-20"
iyy="0.00066906"
iyz="-4.86E-20"
izz="0.0013313" />
</inertial>
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
filename="package://myrobot/meshes/base_link.STL" />
</geometry>
<material
name="">
<color
rgba="0.0549 0.8352941 0.05 1" />
</material>
</visual>
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
</geometry>
</collision>
</link>
<link
name="axis_1">
<inertial>
<origin
xyz="-1.9188529907279E-05 0.0408070112537518 -5.16123564547961E-05"
rpy="0 0 0" />
<mass
value="1.0766304222928" />
<inertia
ixx="0.00448300046656785"
ixy="-3.42116795702848E-07"
ixz="-4.62222489752297E-07"
iyy="0.00764833990366456"
iyz="-9.51387517754669E-07"
izz="0.00478779956731877" />
</inertial>
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
filename="package://myrobot/meshes/axis_1.STL" />
</geometry>
<material
name="">
<color
rgba="0.96078 0.9490196 0.196078 1" />
</material>
</visual>
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
</geometry>
</collision>
</link>
<joint
name="CS1_JY"
type="revolute">
<origin
xyz="0 0 -0.007418"
rpy="1.5708 0 0" />
<parent
link="base_link" />
<child
link="axis_1" />
<axis
xyz="0 1 0" />
<limit
lower="-3.1416"
upper="3.1416"
effort="16.65"
velocity="1.0472" />
</joint>
<link
name="axis_2">
<inertial>
<origin
xyz="0.000584059554378004 0.0287533737382525 0.00295671723448659"
rpy="0 0 0" />
<mass
value="0.605345156556413" />
<inertia
ixx="0.00261234709569383"
ixy="4.5980780114133E-06"
ixz="7.92379593078752E-08"
iyy="0.000455231208205277"
iyz="-4.1286471862465E-05"
izz="0.00228496027770769" />
</inertial>
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
filename="package://myrobot/meshes/axis_2.STL" />
</geometry>
<material
name="">
<color
rgba="0.788235 0.0470588 0.0470588 1" />
</material>
</visual>
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
</geometry>
</collision>
</link>
<joint
name="CS2_JX"
type="revolute">
<origin
xyz="0 0.098418 0"
rpy="-0.5236 0 0" />
<parent
link="axis_1" />
<child
link="axis_2" />
<axis
xyz="1 0 0" />
<limit
lower="0"
upper="2.0944"
effort="16.65"
</joint>
<link
name="axis_3">
<inertial>
<origin
xyz="0.000128226197855751 0.0146819954602909 0.0160853286443578"
rpy="0 0 0" />
<mass
value="0.196627852021408" />
<inertia
ixx="0.000289021312704464"
ixy="-6.53312202419969E-07"
ixz="-3.68984055220104E-07"
iyy="0.000133778182953445"
iyz="-3.90755330630791E-06"
izz="0.000205857020457709" />
</inertial>
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
filename="package://myrobot/meshes/axis_3.STL" />
</geometry>
<material
name="">
<color
</material>
</visual>
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
</geometry>
</collision>
</link>
<joint
name="CS3_JX"
type="revolute">
<origin
xyz="-0.000825 0.2 0"
rpy="0.16184 0 0" />
<parent
link="axis_2" />
<child
link="axis_3" />
<axis
xyz="1 0 0" />
<limit
lower="-3.6826"
upper="0"
effort="16.65"
</joint>
<link
name="axis_4">
<inertial>
<origin
xyz="0.00131830590087079 -3.24283722097363E-08 0.0584468806925138"
rpy="0 0 0" />
<mass
value="0.135666131166316" />
<inertia
ixx="0.000171648323961738"
ixy="7.84809768098463E-11"
ixz="1.67427905148078E-06"
iyy="0.000169180928551479"
iyz="1.3515484895195E-10"
izz="9.63179317550672E-05" />
</inertial>
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
filename="package://myrobot/meshes/axis_4.STL" />
</geometry>
<material
name="">
<color
</material>
</visual>
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
</geometry>
</collision>
</link>
<joint
name="CS4_JZ"
type="revolute">
<origin
xyz="0 0 0.0485"
rpy="0 0 0" />
<parent
link="axis_3" />
<child
link="axis_4" />
<axis
xyz="0 0 1" />
<limit
lower="-3.1416"
upper="3.1416"
effort="0.13333"
</joint>
<link
name="axis_5">
<inertial>
<origin
xyz="0.00240941764072521 -0.00323918544806262 0.00183944664365857"
rpy="0 0 0" />
<mass
value="0.00962563982922243" />
<inertia
ixx="1.04077939599365E-06"
ixy="-7.61747322053136E-08"
ixz="3.48083690608222E-08"
iyy="3.08381331325869E-06"
iyz="-1.3948000676181E-07"
izz="2.30153871190481E-06" />
</inertial>
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
filename="package://myrobot/meshes/axis_5.STL" />
</geometry>
<material
name="">
<color
</material>
</visual>
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
</geometry>
</collision>
</link>
<joint
name="CS5_JX"
type="revolute">
<origin
xyz="0 7.7657E-05 0.10782"
rpy="0.36176 0 0" />
<parent
link="axis_4" />
<child
link="axis_5" />
<axis
xyz="1 0 0" />
<limit
lower="-3.5709"
upper="0"
effort="0.7"
</joint>
<link
name="axis_6">
<inertial>
<origin
xyz="-0.00349269153511097 -0.000919361913902864 0.0342998328213469"
rpy="0 0 0" />
<mass
value="0.0699688456604863" />
<inertia
ixx="1.5098477820153E-05"
ixy="-1.49698854518899E-07"
ixz="-9.08281190378363E-07"
iyy="3.6379829500024E-05"
iyz="-6.77574294129646E-07"
izz="3.15779666601805E-05" />
</inertial>
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
filename="package://myrobot/meshes/axis_6.STL" />
</geometry>
<material
name="">
<color
rgba="0.047058823 0.2313725 0.960784313 1" />
</material>
</visual>
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
</geometry>
</collision>
</link>
<joint
name="CS6_JZ"
type="revolute">
<origin
xyz="0 -0.005947 0.0007956"
rpy="1.4378 0 0" />
<parent
link="axis_5" />
<child
link="axis_6" />
<axis
xyz="0 0 -1" />
<limit
lower="-3.1416"
upper="3.1416"
effort="0.08"
</joint>
<link
name="EFR">
<inertial>
<origin
xyz="-0.0105042612898266 -0.00799999999999999 0.0167121095536187"
rpy="0 0 0" />
<mass
value="0.0163419673619417" />
<inertia
ixx="3.78651345813218E-06"
ixy="2.54749891582919E-23"
ixz="-5.94003603520545E-07"
iyy="4.23427816319959E-06"
iyz="-2.24993126614424E-22"
izz="1.08102197917692E-06" />
</inertial>
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
filename="package://myrobot/meshes/EFR.STL" />
</geometry>
<material
name="">
<color
rgba="0.047058823 0.156862 0.584313725 1" />
</material>
</visual>
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
</geometry>
</collision>
</link>
<joint
name="CSEF_RXminus"
type="prismatic">
<origin
xyz="-0.0013297 0.02 0.0582"
rpy="0 0 0" />
<parent
link="axis_6" />
<child
link="EFR" />
<axis
xyz="-1 0 0" />
<limit
lower="-0.0013297"
upper="0.01367"
effort="0.7"
velocity="0.02" />
</joint>
<link
name="EFL">
<inertial>
<origin
xyz="0.0105042612898266 -0.00800000000000002 0.0167121095536187"
rpy="0 0 0" />
<mass
<inertia
ixx="3.78651345813217E-06"
ixy="-2.18308948311422E-22"
ixz="5.94003603520544E-07"
iyy="4.23427816319958E-06"
iyz="6.88214269644119E-22"
</inertial>
<visual>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
filename="package://myrobot/meshes/EFL.STL" />
</geometry>
<material
name="">
<color
</material>
</visual>
<collision>
<origin
xyz="0 0 0"
rpy="0 0 0" />
<geometry>
<mesh
</geometry>
</collision>
</link>
<joint
name="CSEF_LXplus"
type="prismatic">
<origin
xyz="0.0013297 0.02 0.0582"
rpy="0 0 0" />
<parent
link="axis_6" />
<child
link="EFL" />
<axis
xyz="1 0 0" />
<limit
lower="-0.0013297"
upper="0.01367"
effort="0.7"
velocity="0.02" />
</joint>
<transmission name="trans_CS1_JY">
<type>transmission_interface/SimpleTransmission</type>
<joint name="CS1_JY">
<hardwareInterface>hardware_interface/EffortJointInterface</hardwareInterface>
</joint>
<actuator name="CS1_JY_motor">
<mechanicalReduction>1</mechanicalReduction>
</actuator>
</transmission>
<transmission name="trans_CS2_JX">
<joint name="CS2_JX">
</joint>
<actuator name="CS2_JX_motor">
</actuator>
</transmission>
<transmission name="trans_CS3_JX">
<joint name="CS3_JX">
</joint>
<actuator name="CS3_JX_motor">
</actuator>
</transmission>
<transmission name="trans_CS4_JZ">
<joint name="CS4_JZ">
</joint>
<actuator name="CS4_JZ_motor">
</actuator>
</transmission>
<transmission name="trans_CS5_JX">
<joint name="CS5_JX">
</joint>
<actuator name="CS5_JX_motor">
</actuator>
</transmission>
<transmission name="trans_CS6_JZ">
<joint name="CS6_JZ">
</joint>
<actuator name="CS6_JZ_motor">
</actuator>
</transmission>
<transmission name="trans_CSEF_RXminus">
<joint name="CSEF_RXminus">
</joint>
<actuator name="CSEF_RXminus_motor">
</actuator>
</transmission>
<transmission name="trans_CSEF_LXplus">
<joint name="CSEF_LXplus">
</joint>
<actuator name="CSEF_LXplus_motor">
</actuator>
</transmission>
<gazebo>
<robotNamespace>/myrobot</robotNamespace>
<robotSimType>gazebo_ros_control/DefaultRobotHWSim</robotSimType>
<robotParam>/myrobot/robot_description</robotParam>
<legacyModeNS>true</legacyModeNS>
</plugin>
</gazebo>
</robot>
controller:
myrobot:
# Publish all joint states -----------------------------------
joint_state_controller:
type: joint_state_controller/JointStateController
publish_rate: 50
# Position Controllers ---------------------------------------
joint1_position_controller:
type: effort_controllers/JointEffortController
joint: CS1_JY
pid: {p: 100.0, i: 0.01, d: 10.0}
joint2_position_controller:
joint: CS2_JX
joint3_position_controller:
joint: CS3_JX
joint4_position_controller:
joint: CS4_JZ
joint5_position_controller:
joint: CS5_JX
joint6_position_controller:
joint: CS6_JZ
joint7_position_controller:
joint: CSEF_RXminus
joint8_position_controller:
joint: CSEF_LXplus
Originally posted by msaws on ROS Answers with karma: 3 on 2020-08-17
