Hi guys.
I'm trying to convert point to pose. But i don't know how to do. I saw topic_tool package, but the only example is about stg_msgs. I can't find parameteres that i need. :(
And i also saw 'covert pose to point' (https://answers.ros.org/question/249104/convert-geometry_-msgspose-to-point/) The answer is so simple. But it's not for me.
Thanks you for your interest, Ray.
(edit) Code
rosrun topic_tools transform /clicked_point /clicked_pose geometry_msgs/PoseStamped \
'geometry_msgs.msg.PoseStamped( \
header=m.header,  \
pose=geometry_msgs.msg.Pose( \
  position=m.position, \
  orientation=geometry_msgs.msg.Quaternion( \
orientation.x = 0.0 \
    orientation.y = 0.0 \
orientation.z = 0.0 \
orientation.w = 0.0 \
--import geometry_msgs
Error
[ERROR] [1597812518.884135, 258.643000]: bad callback: <bound method TopicOp.callback of <main.TopicOp instance at 0x7fac8a25ef38>> Traceback (most recent call last): File "/home/raptor/nav_ws/src/ros_comm/clients/rospy/src/rospy/topics.py", line 750, in _invoke_callback cb(msg) File "/home/raptor/nav_ws/src/ros_comm/tools/topic_tools/scripts/transform", line 94, in callback res = eval("{}".format(self.expression), self.modules, {'m': m}) File "", line 7 orientation.y = 0.0
^ SyntaxError: invalid syntax
Originally posted by Ray_Shim on ROS Answers with karma: 27 on 2020-08-17
You can use transform from topic_tools. It is quite useful yet handy tool for which you have to care about. You can see the details of paramters here. Here is an example to use in launch file:
<?xml version="1.0"?>
<launch>
  <node name="diagnostics_stamped" pkg="topic_tools" type="transform"
    args="/diagnostics /diagnostics_stamped diagnostic_msgs/DiagnosticArray
   'diagnostic_msgs.msg.DiagnosticArray(header=std_msgs.msg.Header(
    stamp=rospy.Time.now(), frame_id=m.name),
    status=[diagnostic_msgs.msg.DiagnosticStatus(
    level=m.level, name=m.name, message=m.message, hardware_id=m.hardware_id, values=[])])'
    --import diagnostic_msgs std_msgs rospy"/>
</launch>
To run an from terminal an example can be seen here
Originally posted by Tahir M. with karma: 213 on 2020-08-17
Comment by Ray_Shim on 2020-08-18:
Thanks for your help. But i'm still stuck.
I face problem that i don't know how to write orientation part. I cannot find any reference about orientation. I want to put all 0.0 values in orientation. So I made some simplse code. But i got error msg about syntax.
Could i get some advice about my code? (i upload my code)
