I'm following the instructions for installing ROS2 here and I keep getting the error
sudo: rosdep: command not found
when I run sudo update init. Looking through the files installed in the package python3-rosdep2, I don't see any executable. I tried sudo python3 -m rosdep2 init and it says
/usr/bin/python3: No module named rosdep2.__main__; 'rosdep2' is a package and cannot be directly executed
So I have no idea what to do next. I created an issue on github and was told to ask my question here. After following the instructions given on github I still cannot execute the steps to install and use python3-rosdep2.
Originally posted by towood on ROS Answers with karma: 13 on 2020-08-15
The comment on github has the answer. Uninstall python3-rosdep2, and install python3-rosdep or python-rosdep. python3-rosdep2 is an older version. See this question for more info.
https://answers.ros.org/question/353082/missing-packages-after-installing-rosdep-based-on-python3-rosdep2-in-noetic/
sudo apt-get purge python-rosdep2 python3-rosdep2
sudo apt-get install python3-rosdep
Originally posted by sloretz with karma: 3061 on 2020-08-17
Post score: 4
