Hello,
I want to run Autoware NDT_Matching with ouster-128
I am getting a transform error
For frame [/os1_lidar]: No transform to fixed frame [world].  TF error: [, when looking up transform from frame [os1_lidar] to frame [world]]
I have tested many parameters,
  • voxel_grid_filter
  • ndt_matching
but it can’t transform [/os1_lidar] -> [world] correctly.
Environment: Ubuntu 16.04, ROS Kinetic, Autoware 1.12.0
Originally posted by ken86202 on ROS Answers with karma: 11 on 2020-08-10
Comment by Patrick N. on 2020-08-10:
Did you define a transform from map->world? NDT matching should create a transform relative to map frame.
Comment by ken86202 on 2020-08-10:
Yes I have loaded tf_local.launch (map->world) ,and I have error
For frame [/os1_lidar]: No transform to fixed frame [world].  TF error: [Lookup would require extrapolation into the past.  Requested time 1550.048495240 but the earliest data is at time 1597062760.654010145, when looking up transform from frame [os1_lidar] to frame [world]]
Are you replaying recorded data?
yes I play rosbag
Are you using the simulation tab on the gui or setting the use_sim_time rosparam. Seems like some part of your TF tree is using system time and another part using something else.
By default, Autoware.AI does not understand the frame /os1_lidar because it assumes that the lidar's frame is /velodyne. There are a few ways to correct this:
  1. Change your Ouster driver to publish the point clouds with the frame velodyne. (easiest)
  2. Change the code / launch files / configuration files to expect the frame os1_lidar. (hardest)
  3. Change the localizer parameter in ndt_matching to os1_lidar and publish a static transform between os1_lidar and velodyne with parameters 0 0 0 0 0 0. (this is unttested but may work)
Originally posted by Josh Whitley with karma: 1766 on 2020-08-13
