A few guidelines to help you search:
Max displacement: +/- 5mm.
Frequency: 60Hz = 377 rad/s.
Now, some math:
x = 0.005 \sin{(377 t)} \\
v = (377)(0.005) \cos{(377 t)} \\
a = -(377^2)(0.005) \sin{377 t)} \\
Then, the max values are wherever the particular trig function is equal to 1, so:
x_{\mbox{max}} = 0.005 \mbox{m}\\
v_{\mbox{max}} = 1.9 \mbox{m/s}\\
a_{\mbox{max}} = 710 \mbox{m/s}^2 \approx 72 \mbox{g}\\
Now, $F = ma$, so the peak force you are applying is:
F = ma \\
F = (0.3)(710) \\
F = 213 \mbox{N} \\
Peak power is force times speed.
P = (213)(1.9) \\
P = 405 W \\
Per your guidelines, you want (I'm assuming) a cylinder that's 0.05m long and 0.01m in diameter. This means that the volume is (approximately)
V = Ah \\
V = \pi r^2 h \\
V = \pi (0.005)^2 (0.05) \\
V = 0.00000393 \mbox{m}^3 \\
V = 0.00393 \mbox{liters} \\
V = 3927 \mbox{mm}^3 \\
Now, you can try looking at power density and see that you want 405W of peak power in a space of 0.00393 liters, or a power density of about $405/0.00393 = \boxed{103 \mbox{W/l}}$, or about the same power density as a Ferrari engine.
I'm not saying it's not possible, but good luck.
If you are a PhD student at a university, you should consider asking your committee members to guide you to another grad student for assistance with this.
Typically I would vote to close an open-ended design/shopping question like this, but I figured I'd go through the steps to show that what you want isn't really attainable.
