Hi,
I am doing 3D mapping with Kinect 360 camera using RTABMAP. Mapping starts well and then I start getting this two errors:
  1. "[ WARN] (2020-07-22 14:50:09.654) Rtabmap.cpp:2144::process() Rejected loop closure 93 -> 173: Too large rotation detected! (pitch=0.000000, yaw=0.000000) max is -1.628242"
  2. [ WARN] (2020-07-22 14:57:33.872) Rtabmap.cpp:2144::process() Rejected loop closure 57 -> 99: Not enough inliers after bundle adjustment 0/20 (matches=70) between 57 and 99
They occur in between lots of successful readings. For moving a robot I use:
rostopic pub -1 cmd_vel geometry_msgs/Twist '[0.1, 0, 0]' '[0, 0, 0]'
and for rotation I use:
rostopic pub -1 cmd_vel geometry_msgs/Twist '[0, 0, 0]' '[0, 0, 0.1]'
I am using Pioneer 3-AT with ROS Melodic.
Here is my Gazebo world: https://imgur.com/a/B1bPeDE Here are my map when it is still correct: https://imgur.com/a/4Iqg4Tg, and when error occurs: https://imgur.com/a/vv7x60W
Here is my rtabmap.launch file:
<launch>
<param name="/use_sim_time" value="true"/>
<node pkg="nodelet" type="nodelet" name="rgbd_sync" args="standalone rtabmap_ros/rgbd_sync" output="screen">
      <remap from="rgb/image"        to="/camera/rgb/image_raw"/>
      <remap from="depth/image"      to="/camera/depth/image_raw"/>
      <remap from="rgb/camera_info"  to="/camera/rgb/camera_info"/>
      <remap from="rgbd_image"       to="rgbd_image"/> <!-- output -->
      <!-- Should be true for not synchronized camera topics
       (e.g., false for kinectv2, zed, realsense, true for xtion, kinect360)-->
      <param name="approx_sync"       value="true"/>
    <param name="queue_size"  type="int"  value="10"/>
    </node>
<!-- Odometry -->
<node pkg="rtabmap_ros" type="rgbd_odometry" name="rgbd_odometry" output="screen">
    <!--param name="subscribe_rgbd" type="bool"   value="true"/-->
    <param name="frame_id"       type="string" value="base_link"/>
    <param name="publish_tf"  type="bool"   value="false"/>
</node>
  <param name="map_frame" value="map"/>
  <param name="odom_frame" value="odom"/>
  <param name="base_link_frame" value="base_link"/>
  <param name="world_frame" value="map"/>
  <param name="odom0" value="odom"/>
  <param name="pose0" value="rtabmap/localization_pose"/>
  <!-- The order of the values is x, y, z, roll, pitch, yaw, vx, vy, vz, vroll, vpitch, vyaw, ax, ay, az. -->
  <rosparam param="odom0_config">[true, true, false,
                                  false, false, true,
                                  false, false, false,
                                  false, false, false]</rosparam>
  <rosparam param="pose0_config">[
                                 true,   true,  false,
                                 false,  false, true,
                                 false,  false, false] </rosparam>
  <param name="odom0_differential" value="true"/>
  <param name="pose0_differential" value="false"/>
  <param name="odom0_relative" value="true"/>
  <param name="pose0_relative" value="false"/>
  <param name="odom0_queue_size" value="5"/>
  <param name="pose0_queue_size" value="2"/>
<node name="rtabmap" pkg="rtabmap_ros" type="rtabmap" output="screen" args="--delete_db_on_start">
    <param name="frame_id"        type="string" value="map"/>
    <param name="subscribe_depth" type="bool"   value="false"/>
    <param name="subscribe_rgbd"  type="bool"   value="true"/>
    <remap from="odom"       to="odom"/>
    <param name="queue_size"  type="int"  value="500"/>
    <param name="approx_sync" type="bool" value="false"/>
    <!-- RTAB-Map's parameters -->
    <param name="RGBD/AngularUpdate"        type="string" value="0.01"/>
    <param name="RGBD/LinearUpdate"         type="string" value="0.01"/>
    <param name="RGBD/OptimizeFromGraphEnd" type="string" value="false"/>
    <param name="RGBD/OptimizeMaxError" type="int" value="0"/>
    <!--param name="Grid/FromDepth" type="string" value="false"/-->
    <param name="sensor_model/hit" value="1" />
    <param name="sensor_model/miss" value="0" />
    <param name="Reg/Force3DoF" value="true"/> <!-- 2D mode -->
    <!--param name="publish_tf"  type="bool"   value="false"/-->
    <param name="sensor_model/max_range" value="5.0" />
    <param name="latch" value="false" />
</node>
Did someone have this problem or does someone know how to fix it? Thanks in advance.
Best regards.
Originally posted by leodomitrovic on ROS Answers with karma: 33 on 2020-07-22
Those are warnings, and they mean the loop closure has been rejected because the returned transform was wrong or because there were not enough inliers. Your environment seems to have a lot of repetitive textures, this could generate those kind of rejections. You can ignore hem unless real loop closures are not found or rejected.
Originally posted by matlabbe with karma: 6409 on 2020-08-21
Comment by leodomitrovic on 2020-08-22:
Ok. Thank you for your answer.
