My directory structure is as recommended by the documentation:
├─ ros1_ws
│  └─ src
│     └─ bridge_msgs
│        └─ msg
│           └─ MyMessage.msg
├─ ros2_ws
│  └─ src
│     └─ bridge_msgs
│        ├─ msg
│           └─ MyMessage.msg
└─ bridge
   └─ src
      └─ ros1_bridge
When building, I get the following error
In file included from bridge/build/ros1_bridge/generated/get_factory.cpp:9:
bridge/build/ros1_bridge/generated/bridge_msgs_factories.hpp:13:10: fatal error: bridge_msgs/msg/my_message.hpp: No such file or directory
 #include <bridge_msgs/msg/my_message.hpp>
I inspected ros1_bridge/generated/bridge_msgs__msg__MyMessage__factories.cpp and it contains the relevant mapping (not dummy).
Also, the relevant my_message.hpp file has been generated beforehand in
./ros2_ws/install/bridge_msgs/include/bridge_msgs/msg/my_message.hpp
./ros2_ws/build/bridge_msgs/rosidl_generator_cpp/bridge_msgs/msg/my_message.hpp
I've tried multiple clean rebuilds of all workspaces, sourcing and building bridge last
Originally posted by Rufus on ROS Answers with karma: 1083 on 2020-07-14
It seems before sourcing, I should clean all ROS related environment variables first. This solved my problem
unset $(env | grep "ROS_\|AMENT_\|COLCON_\|CATKIN_" | egrep -o '^[^=]+')
Originally posted by Rufus with karma: 1083 on 2020-07-15
