Hello, I'm new in ROS. When I tried to run robot_localization package by this command: roslaunch robot_localization ekf_template.launch I have met this issue below:
ERROR: cannot launch node of type [robot_localization/ekf_localization_node]: Cannot locate node of type [ekf_localization_node] in package [robot_localization]. Make sure file exists in package path and permission is set to executable (chmod +x)
I had run these commands before that:
source devel/setup.bash
and
source /opt/ros/melodic/setup.bash
So can I fix it? Many thanks.
[UPDATE] When I used the command:
rosrun robot_localization ekf_localization_node
I got:
[rosrun] Couldn't find executable named ekf_localization_node below /home/swarm-robotics/catkin_ws/src/robot_localization
Originally posted by HieuPham on ROS Answers with karma: 3 on 2020-07-03
As per info in your question, you first ran
to source your workspace and then:
Which is the cause it's not working. First run
followed by sourcing your workspace and it should work if everything else is fine. Also, make sure you ran catkin_make in the workspace you have the package in.
Originally posted by parzival with karma: 463 on 2020-07-04
Comment by HieuPham on 2020-07-04:
Many thanks, In my case, if I ran 2 commands follow your guide, it not working but it's ok when I run only source devel/setup.bash When I ran catkin_make --pkg robot_localization again, it's working correctly. I think when I used catkin_make command previously, I make a few mistakes but I skipped it.
