Using an Ubuntu 18.04 PC with ROS Melodic and a BeagleBone with Ubuntu 18.04 and ROS Melodic everything works fine. I am now testing a Ubuntu 20.04 PC with ROS Melodic. If I run the ROS Master on the BeagleBone (still Ubuntu 18.04 and ROS Melodic) the PC can communicate with the BeagleBone via ROS.
But if the ROS Master is runnung on the PC the BeaglBone ROS Melodic does not find this ROS Master. Ping commands between these two machines work fine and the Variables like ROS_MASTER_URI are correctly set. I have a similar Problem if I run Simulink with the latest ROS Toolbox on my PC.
Is it possible in general, that ROS Noetic can communicate with a ROS Melodic Master but not the other way around? Do I need to have ROS Noetic also on the BeagleBone?
Edit: Thanks for your quick response: On the BeagleBone (BB) I flashed a ready to use image from elinux.org https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#ROS_.28ROS_Melodic_Morenia.29_-_Weekly On the PC I first installed Ubuntu 20.04 and the ROS Noetic via apt-get.
The PC and BB are connected via USB (virtual IP-connection ethernet over USB). Pings from both sides work fine.
Here detailed informations:
ROS Master (Noetic 1.15.7) on Ubuntu 20.04 PC:
export ROS_MASTER_URI=http://192.168.6.1:11311
export ROS_HOSTNAME=192.168.6.1
Output command "roscore":
... logging to /home/master/.ros/log/4300ceee-aed7-11ea-ba2a-b7f88a7d75c9/roslaunch-ssdtogo-4503.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
started roslaunch server http://192.168.6.1:40083/
ros_comm version 1.15.7
SUMMARY
PARAMETERS
 * /rosdistro: noetic
 * /rosversion: 1.15.7
NODES
auto-starting new master
process[master]: started with pid [4513]
ROS_MASTER_URI=http://192.168.6.1:11311/
setting /run_id to 4300ceee-aed7-11ea-ba2a-b7f88a7d75c9
process[rosout-1]: started with pid [4523]
started core service [/rosout]
ROS Node (Melodic 1.14.3) on Ubuntu 18.04 BeagleBone:
export ROS_HOSTNAME=192.168.6.2
Output command "rosrun srp_init gpio_talker.py":
GPIO-Talker starting...
[ERROR] [1592205938.965650]: Unable to immediately register with master node [http://192.168.6.1:11311]: master may not be running yet. Will keep trying.
Source code gpio_talker.py:
#!/usr/bin/env python
#-*- coding: utf-8 -*-
## Simple talker reading P9_11 (GPIO 30) and publishing
## value as UInt8 on topic 'gpio_val'
import rospy
import Adafruit_BBIO.GPIO as GPIO
from std_msgs.msg import UInt8
def talker():
    pub = rospy.Publisher('gpio_val', UInt8, queue_size=10)
    rospy.init_node('GPIOTalker', anonymous=False)
    rate = rospy.Rate(10)
    GPIO.setup("P9_11", GPIO.IN)
    print('GPIO setup done...')
        gpio_val = GPIO.input("P9_11") # int value returned
        #rospy.loginfo('Talker: GPIO value = ' + str(gpio_val))
        pub.publish(gpio_val)
        rate.sleep()
if __name__ == '__main__':
    try:
        print('GPIO-Talker starting...')
        talker()
    except rospy.ROSInterruptException:
        print('ROSInterruptException')
        pass
    finally:
        GPIO.cleanup() # Bewirkt unexport
        print('...Pin disabled.')
        print('Byebye...')
Originally posted by robotogo on ROS Answers with karma: 11 on 2020-06-14
Comment by gvdhoorn on 2020-06-14:\
Built from source? Or do you mean: I'm trying to exchange messages between ROS Noetic on Focal (20.04) with Melodic on Bionic (18.04)?
Please include the values of those variables here, so we can make sure.
As to the rest of your problem description: you'll need to tell us which messages or services aren't working for you. There could well have been changes, but without knowing which messages you're attempting to use, no one can help you.
Problem solved: The (new?) Ubuntu 20.04 firewall was blocking the ROS communication
Thanks for the quick and competent answers.
In the end I followed the suggestions how to debug the network connection as proposed in http://wiki.ros.org/ROS/NetworkSetup. Doing this I realized, that ping worked but I could not establish a connection using netcat -l 11311 on the PC and netcat 192.168.6.1 11311 on the BeagleBone. Hence it became clear that my BeagleBone could not reach his ROS-Master via ROS_MASTER_URI=http://192.168.6.1:11311/ :-(
My problem came up because I switched from Ubuntu 18.04 to 20.04 on the PC. Honestly I never heard anything about a firewall on Ubuntu 18.04. But actually on Ubuntu 20.04 a firewall is set active by default. But it is possible to deactivate the Ubuntu 20.04 firewall:
master@ssdtogo:~/Work$ sudo ufw status
Status: Aktiv
master@ssdtogo:~/Work$ sudo ufw disable
Firewall gestoppt und beim Systemstart deaktiviert
Status: Inaktiv
Now everything works fine. Has anybody any suggestions how to safely deactivate the Ubuntu 20.04 firewall - I mean to only set an exception for the ROS communication?
Originally posted by robotogo with karma: 11 on 2020-06-17
