Hi everyone,
I have successfully created few ROS2 nodes (one for a publisher with customer message, the custom message one, one responsible for debugging, one for the subscriber).
I have repeated the exact same steps in order to create some other packages. However, the last one that I created returns "No executable found".
I am developing using python3.
I am pretty sure that package.xml, setup.py, setup.cfg and the actual node class are fine.
Also, no issues when running rosdep, all fine with colcon build, and I have installed everything with . install/setup.bash.
What could the problem be? Any idea?
Thanks in advance, G.
Originally posted by anthares on ROS Answers with karma: 60 on 2020-06-12
Comment by swaroophs on 2020-06-12:
Do you see the executable when you run?
ros2 pkg executables <pkg_name>
Comment by anthares on 2020-06-12:
yes, I can see the package being there...
Comment by Uik on 2022-07-13:
in my case, i didn't see anything with this command
