Hi folks,
I have just upgraded to Ubuntu 20.04 LTS, and ROS Noetic. Following the instructions in the ROS tutorials, using ROS Noetic, everything worked fine except for the tutorial about installing Arduino IDE Setup: http://wiki.ros.org/rosserial_arduino/Tutorials/Arduino%20IDE%20Setup I do the 2.1.1 (RECOMMENDED) Installing Binaries on the ROS workstation:
sudo apt-get install ros-noetic-rosserial-arduino
Reading package lists... Done
Building dependency tree
E: Unable to locate package ros-noetic-rosserial-arduino
I suspect that the rosserial Arduino package is not yet provided for noetic. Am I right? Does anyone know when/if it will be? Or can I install this package in another way? I tried the build from source option too, but no success there... it simply does not work when I try to run the simple helloworld example in the next tutorial. Before I upgraded to Ubuntu 20.04, I ran 18.04 and melodic. It worked fine! Any help/advice much appreciated! All the best, Krister
Originally posted by Saul on ROS Answers with karma: 1 on 2020-06-02
