If you have specified your costmap layers using the hydro+ API, you can set the map_topic
parameter under the static_map
plugin namespace in your navigation configuration files. See the staticmap page for more information.
You can learn more about the hydro version of the costmap_2d stack here
This would often get placed in the costmap_common_parameters.yaml
file in a hydro setup. You can see an example of that here on a branch I have worked on.
Note that in the above case, you would add the following lines to the costmap_common_params.yaml
file:
static_layer:
map_topic: /map_filtered
because the staticmap plugin was specified to be in the static_layer
namespace in the global_costmap_params.yaml file on the same branch.
Originally posted by maxsvetlik with karma: 161 on 2020-05-20
Comment by Yehor on 2020-05-21:
@maxsvetlik Thank you
