Hi,
Can someone shed some light on how to display lasercan obstacles for use in Navigation Stack (AMCL+MOVE_BASE, ubuntu 18.04, Melodic)?
I spent lots of time changing configurations and searching for answers but I can't figure out how to consider obstacles detected by lasercan as in this image:
https://drive.google.com/open?id=1WxaY8cegTQQEh0aSPu24EqrngDP1EraU
In the image there is an obstacle (pointed in RED) as detected by laserscan but is not marked as obstacle by local map.
However if I change common costmap file and remove "plugins" section going back to pre-Hidro parameters it is showed as image below.
https://drive.google.com/open?id=1rubBdsOHd7ypbb_39yodAKZWbizF9VXn
Hera are my relevant config files:
costmap_common_params.yaml
obstacle_range: 2.5
raytrace_range: 3.0
footprint: [[-0.2,-0.2],[-0.2,0.2], [0.2, 0.2], [0.2,-0.2]]
inflation_radius: 0.30  # max. distance from an obstacle at which costs are incurred for planning paths.
cost_scaling_factor: 50  # exponential rate at which the obstacle cost drops off (default 10)
observation_sources: scan
scan: {data_type: LaserScan, sensor_frame: base_link, topic: /zed/scan, marking: true, clearing: true, min_obstacle_height: 0.0, max_obstacle_height: 0.50}
plugins:
- {name: static_map,               type: "costmap_2d::StaticLayer"}
- {name: obstacle_2d_layer,   type: "costmap_2d::ObstacleLayer"}
- {name: inflation,                   type: "costmap_2d::InflationLayer"}
global_costmap_params.yaml
global_costmap:
global_frame: map
robot_base_frame: base_link
update_frequency: 1.0
#static_map: true
publish_frequency: 0.5
transform_tolerance: 1.0
#resolution: 0.010
local_costmap_params.xml
local_costmap:
global_frame: odom  # odom DGPP
update_frequency: 2.0
publish_frequency: 2.0
#static_map: false
rolling_window: true
width: 3.0
height: 3.0
resolution: 0.05
As mentioned, if I just comment the plugin item with the three topics from costmap_common file it shows the obstacle. It also show some errors (not important) in terminal but shows the obstacle as second image above.
I am using TrajectoryPlannerROS (not DWA).
Can someone shed some light on how to display lasercan obstacle for use in Navigation Stack (AMCL+MOVE_BASE)?
Thank you,
Originally posted by dpetrini on ROS Answers with karma: 23 on 2020-05-14
I will answer my own question:
After keep looking for answers and trying many combinations, I discover that is all about syntax.
It seems different versions (using directive "plugins:" or not) eventually requires proper manner to write files.
The solution of my issue above was to write the common_costmap_params.xml file as below:
obstacle_range: 2.5
raytrace_range: 3.0
inflation:
obstacle_2d_layer:
    scan: {data_type: LaserScan, sensor_frame: zed_left_camera_frame, topic: /zed/scan, marking: true, clearing: true, min_obstacle_height: 0.0, max_obstacle_height: 0.5}
plugins:
As you can see the "inflation" and "obstacle_2d_layer" keywords (as pointed as "name" inside plugins) need to be exposed like that. Doing this obstacles showed up like a charm.
Originally posted by dpetrini with karma: 23 on 2020-05-14
