From the following answer by @dhood it says that since Crystal modifications for the nodes name/namespace in launch files will also be taken into account for the parameter YAML file:
https://answers.ros.org/question/304346/ros2-yaml-config-file-without-node-name/?answer=304347#post-id-304347
This seems not to work for me.
I am using Ubuntu 18.04 in a VM with ROS Eloquent installed. I am using turtlesim for my tests. My turtlesim.yaml looks as follows:
turtlesim:
  ros__parameters:
    background_b: 0
    background_g: 0
    background_r: 190
    use_sim_time: false
And that is the dedicated turtle.launch.py file:
#!/usr/bin/env python3
import os
from ament_index_python.packages import get_package_share_directory
from launch_ros.actions import Node
    my_first_pkg = get_package_share_directory('myfirstpackage')
    return LaunchDescription([
        Node(
            package='turtlesim',
            node_executable='turtlesim_node',
            node_namespace='new_turtle',
            parameters=[os.path.join(my_first_pkg, 'turtlesim.yaml')],
            output='screen'),
        Node(
            node_executable='draw_square',
            output='log'),
I am expecting now turtlesim to startup with a red background, but it is not affected and still got the default background. If I am extending the node namespace in the YAML parameter file as following, it does work:
new_turtle/turtlesim:
  ros__parameters:
    background_b: 0
    background_g: 0
    background_r: 190
    use_sim_time: false
===========Edit1===========
The logging does also not work: calling ros2 launch myfirstpackage turtle.launch.py --ros-args --log-level debug ends in:
usage: ros2 [-h] Call `ros2 <command> -h` for more detailed usage. ...
ros2: error: unrecognized arguments: --ros-args --log-level debug
And ros2 param list shows only the parameters from the node within the namespace:
/new_turtle/turtlesim:
  background_b
  background_g
  background_r
  use_sim_time
But the values still haven't changed.
Originally posted by RodBelaFarin on ROS Answers with karma: 235 on 2020-04-21
Comment by dhood on 2020-04-21:
Not an answer, just a troubleshooting tip: you could try reading the debug output from the ROS 2 core as it is handling your parameter file. That might give you extra insight into what is going on. You can enable the debug output in Eloquent by --ros-args --log-level debug to the end of your ros2 launch call from the command line. (see https://index.ros.org/doc/ros2/Tutorials/Logging-and-logger-configuration/ for usage in other ROS 2 versions). You could inspect the messages with rqt_console. Also you might want to inspect the parameters on the nodes with ros2 param tools to know any parameters were applied or not.
Comment by RodBelaFarin on 2020-04-21:
Update in Edit1
Comment by dhood on 2020-04-22:
Thanks for the edits - I think I misunderstood your original post. (plus that log-level command doesn't seem to be used by ros2 launch in that way, oops!)
Is it that you want to make the node so it's not in the namespace? And what you are seeing is that you are only able to make the parameters apply to the /new_turtle/turtlesim node, but you want instead to have your node as just /turtlesim not in a namespace, and can't get the parameters to apply to it in that case?
If that's the case, you need to modify the yaml file like you did, yes, but additionally you also need to remove the node_namespace='new_turtle' line from the launch file, to stop the node being put into the namespace. Does that sound right for your situation?
Comment by RodBelaFarin on 2020-04-22:
Thanks for the support - OK, let me try to explain it again, sorry for my misleading explanations. I have turtlesim and parameters that I want to have set, when I start the node. I am using a launch file to startup this setup. So far, so good. Now I want to have an additional turtlesim (well that was not clear - now I get it). Anyway, I want to have an additional turtlesim node in a different namespace /new_turtle starting up with the same yaml parameter file. How do I do that?
oh ok! I think I see what you want now. In that case, you'd need two entries in the yaml file, one for the node /turtlesim and /new_turtle/turtlesim, is that what you're doing?
Or, programmatically, you could create one python dictionary of parameters, and pass that to both Nodes in the launch file.
oh, or you could try this approach with the double asterisks instead of specifying the node name! https://answers.ros.org/question/304346/ros2-yaml-config-file-without-node-name/?answer=339645#post-id-339645 I haven't tried that myself but it looks like it might do what you want. That's a new feature that wasn't available at the time of Crystal
Yes, the double asterisk workaround does work! I didn't even tried it, because I was still thinking in a global parameter server as in ROS1 and I thought that this will affect ALL parameters with the name background_r for example. In that way it would have affected both turtlesim nodes, but yeah - parameters are now dedicated to one node.
In that case I am wondering why not by default the ros2 param dump command saves the *.yaml file using the /** instead of the node name. I would say that's much more intentional and more user-friendly. But thanks @dhood
Good to hear you got it doing what you wanted!!
As pointed out by @dhood in the comments, using double asterisk in the *.yaml file solves my problem.
I changed my *.yaml as following and can now change the namespace or node name in my launch file:
  ros__parameters:
    background_b: 0
    background_g: 0
    background_r: 190
    use_sim_time: false
Originally posted by RodBelaFarin with karma: 235 on 2020-04-22
Post score: 4
