Hi there,
I've been using xacro.process_file(<file_name>)
to convert from xacro to urdf, it works just fine. Now I have implemented a xacro argument in my file and I want to pass that from my launch file. It just doesn't get read with my current implementation.
XACRO:
<xacro:arg name="simulate_obstacles" default="true"/>
<xacro:if value="$(arg simulate_obstacles)">
<...doing_something...>
</xacro:if>
LAUNCH FILE:
doc = xacro.process_file(xacro_file, simulate_obstacles='false')
When running the xacro from the commandline I don't have any problem passing arguments. What am I doing wrong here? Or is there even a more simple way to use xacro in launch files in ROS2?
Thank you!
Working with eloquent.
Originally posted by relffok on ROS Answers with karma: 169 on 2020-04-17
