I have installed and run the mjpeg_server in my pi 4b and ubuntu 18 machie. in pi i am using image_transport node to publish image. after that i ran mjpeg_server node in pi. But when i try to view the image in web i can't access it. When i run the mjpeg_server node in ubuntu machine i can easily access the image with url:
http://localhost:11311/stream?topic=/camera/image
But similary when i try to access the image topic after running the mjpeg server in pi with url:
http://192.168.4.1:11311/stream?topic=/camera/image
i'm not able to access the image.
Wht is the problem here.
Originally posted by dinesh on ROS Answers with karma: 932 on 2020-04-12
Ok. after i changed the port numbr 11311 to 8181 which is default port number for published images from mjpeg_server it is workng.
Originally posted by dinesh with karma: 932 on 2020-04-12
