I am running ROS2 eloquent on Ubuntu 18.04 and just performed a sudo apt-get install ros-eloquent-rqt-tf-tree and tried running the command in the terminal. The first time I ran it I received the error qt_gui_main() found no plugin matching "rqt_tf_tree.tf_tree.RosTfTree". I then ran the same rqt_tf_tree command with --force-discover and after that, I began receiving service not available, waiting again... repeatedly each time I ran it. Both /tf and /tf_static are being published to by the ROS2 robot state publisher. Any help is greatly appreciated.
Originally posted by mequi on ROS Answers with karma: 111 on 2020-04-11
Comment by Phgo on 2020-04-15:
I have experienced exactly the same issue (ubuntu 18.04, ROS eloquent). There is also a related issue on the rqt-tf-tree GitHub page and another similar question on ROS-Answer.
Unfortunately, none of these provides a solution to this issue and I was not able to come up with one either.
From what I know tf is still a work in progress in ROS eloquent, thus this currently might even be the "expected" behavior, as some relevant parts might still be missing. (?)
I would really appreciate it if someone could confirm that this is i fact true or rather a configuration issue/bug.
Comment by webvenky on 2020-04-28:
Facing the same issue.
After looking a little deeper into this issue, I will try to form an answer from my findings:
Currently, there is only preliminary support for tf2 in ROS 2, and although rqt_tf_free has been released, some parts of tf2 are apparently still a work in progress.
In order to work properly, rqt_tf_tree relies on the tf2_frames service, which however is not yet available in the latest release of tf2_ros (0.12.5). This pending dependency is also pointed out here. However, the corresponding pull request to reactivate the frame graph service in tf2_ros (https://github.com/ros2/geometry2/pull/198), is still open.
Though this will probably be resolved in one the upcoming releases, I would find it really useful if this could be mentioned somewhere in the readme.
In the meantime, you might want to take a look at view_frames in the tf2_tools package (https://github.com/ros2/geometry2/tree/ros2/tf2_tools) that allows you to visualize your tf-tree in a similar way. (At the time writing, tf2_tools is not yet available in the package repository, so you need to install it from source.)
Note: if the rqt_tf_tree plugin prevents your rqt-GUI from opening, you simply need to reset your config by rqt --clear-config (see this question)
Originally posted by Phgo with karma: 218 on 2020-04-29
