In Hokuyo Laser the scan values are getting dealyed from gazebo
  <gazebo reference="hokuyo_link">
<sensor type="ray" name="head_hokuyo_sensor">
  <pose>0.0 0 0.0 0 -0 0</pose>
  <ray>
    <scan>
      <horizontal>
        <samples>720</samples>
        <resolution>1</resolution>
        <min_angle>-1.58079</min_angle>
        <max_angle>1.58079</max_angle>
      </horizontal>
    </scan>
    <range>
      <min>0.08</min>
      <max>5</max>
      <resolution>0.01</resolution>
    </range>
    <noise>
      <type>gaussian</type>
      <mean>0.0</mean>
      <stddev>0.01</stddev>
    </noise>
  </ray>
  <plugin name="gazebo_ros_head_hokuyo_controller" filename="libgazebo_ros_laser.so">
    <always_on>1</always_on>
    <topicName>/sk/laser/scan</topicName>
    <frameName>hokuyo_link</frameName>
    <visualize>true</visualize>
  </plugin>
  <update_rate>30</update_rate>
</sensor>
gazebo veiw
Originally posted by me_saw on ROS Answers with karma: 31 on 2020-04-04
Comment by Teo Cardoso on 2020-04-05:
Could you formulate better your question? Show us more data about the problem. It helps us to help you.
Comment by me_saw on 2020-04-06:
Laser values are not getting accurately, laser is kind of blinking so some values are missing from left and and right
Comment by Teo Cardoso on 2020-04-06:
I tried here your laser settings on my robot. And the laser is working fine.
https://pasteboard.co/J2zz95B.png
I just copy and paste what you post here. So the problem isn't in the code.
Then what could be the problem? It's like the laser is flickering from left and right to some angle because of this laser values are missing
I was checking here and increase the range tag
Try to increase <min>0.08</min>
The values are just an example, but it is a good start.
Originally posted by Teo Cardoso with karma: 378 on 2020-04-06
Isn't the clip tag used in camera plugin?
Sorry, I'm out of my mind. Try to increase 0.08
No problem Thanks I'll try it out
Thank you:) it solved the problem I increased the min to 0.28 and it's working perfectly. I guess the problem was the dimensions of my model
can you answer it separate so that I can mark it as correct.
I edited the comment. I'm glad to help ^^
