Hello
We have the following use case: Control a drone based on object (people) detections coming from a video stream.
To simulate this within Gazebo, we would have to simulate the stream of incoming object detections since we don't have the real camera input that we can run inference on. I searched the internet to find out if something like this already exists but couldn't find anything. Am I missing something, is anyone familiar with a package like that?
The working principle would be as follow. Given we have a camera with given intrinsics positioned at some location looking in some direction and given an object which we place somewhere in the world (could be a cube), what would the resulting bounding box be on the image plane based on the object's silhouette?
Cheers, Matt
Originally posted by matt_robo on ROS Answers with karma: 1 on 2020-03-24
Comment by Weasfas on 2020-03-24:
Hi @matt_robo,
Maybe I did not understand you but, why not using a camera plugin to process the output with OpenCV for instance.
Comment by nkhedekar on 2020-03-24:
Gazebo can provide the ground truth location of the object as well as your drone, so you could do a tf lookup to get the position.
Comment by Anukriti on 2021-08-06:
Hey, were you able to find any solution?
Comment by Fetullah Atas on 2021-08-06:
This better would have been a comment
Gazebo is a 3D simulator. Every object within a world is model with certain physical/dynamical properties. For your case, You could use a camera plugin provided by gazebo. This will let you to capture a desired FOV of World you are simulating as 2D image, you can then place your human models into FOV and simulate a camera stream including objects and maybe some background.
Gazebo’s API is brilliant, you can write a World Plugin, through that world plug-in you can access to every model, as other person answered above, each models also have a 3D Collision Box. Since you know the camera position in the world you can determine the object (models) that are on camera FOV.
From there you will need to do two transforms to get that 3D box overlayed onto your image. First, since the pose of that 3D box is in World frame, you have to transform that to camera frame, after you have the pose in camera frame, you then use camera instrinstic parameters to get pixel coordinates of 3D box in image. Note that, since this is a 3D box, you will have 8 corners in image, but it’s easy to just get minimum 2D bounding box that covers all this 8 corners. This 2D bounding box then can be used as a Grojnd truth, and from there it’s up to you if you want to use this data for a Neural Network training.
this answer was more intended to give an high level overview of steps rather than some practical help. Hope it’s useful somehow. Cheers !
Originally posted by Fetullah Atas with karma: 819 on 2021-08-06
I have done something similar in one of my projects but due to confidential reasons, I cant simply give you the code but I'll structure a general idea of how to implement it. I hope that this might be what you and other people are looking for since I was also struggling with this back then:
  1. You would have to write some ground truth object position which would find where the object's position is with respect to your robot base_link and publish those messages into a topic
  2. Now, your robot base_link is generally the "world coordinate" and you would have to find the transformation from base_link to the camera_frame. have a look at slide 7
  3. After transforming it to the camera coordinate, now you should project the 3d image into 2d image plane and this can be done easily using the image geometry pinholecameramodel
  4. You should now get the pixel coordinate of the object's position with respect to the camera
  5. If your robot has a camera plugin, you can get the live camera feed by subscribing to the any topics with an image type
Here is how you can get the live camera feed from your camera plugin:
#!/usr/bin/env python
import rclpy
import time
import message_filters
import cv2
from cv_bridge import CvBridge, CvBridgeError
from rclpy.qos import qos_profile_sensor_data, QoSProfile
from rclpy.node import Node
from sensor_msgs.msg import Image, CameraInfo
from image_geometry import PinholeCameraModel
from eufs_msgs.msg import BoundingBoxes
class BoundingBox():
    def __init__(self):
        self.cone_list = {'blue':[],'yellow':[],'orange':[], 'big orange':[], 'unknown':[]}
class DrawBoundingBox(Node):
    def __init__(self):
        super().__init__('bounding_box_node')
        self.declare_parameter('camera_image_topic', 'zed/left/image_rect_color')
        self.camera_image_topic = self.get_parameter('camera_image_topic').get_parameter_value().string_value
        qos_profile = qos_profile_sensor_data
        # For image topic, you need to set it to equal to qos_profile sensor data because we are using
        # the data from the zed camera
        self.image_sub = message_filters.Subscriber(
            self,
            Image,
            self.camera_image_topic,
            qos_profile=qos_profile)
        self.bounding_box_sub = message_filters.Subscriber(
            self,
            BoundingBoxes,
            '/simulate_bounding_boxes')
        sync_ = message_filters.ApproximateTimeSynchronizer([self.image_sub, self.bounding_box_sub], 10, 0.5)
        sync_.registerCallback(self.image_callback)
    def image_callback(self, image_msg, bounding_box_msg):
        debug = False
        try:
            self.bridge = CvBridge()
            cv_image = self.bridge.imgmsg_to_cv2(image_msg, desired_encoding="bgr8")
            for cone in bounding_box_msg.bounding_boxes:
                if debug:
                    cv2.circle(cv_image, (int(cone.xmin), int(cone.ymin)), 3, (255,0,0))
                else:
                    cv2.rectangle(cv_image, (int(cone.xmin), int(cone.ymax)), (int(cone.xmax),int(cone.ymin)), (255,0,0))
            cv2.imshow(f'From {self.camera_image_topic} ', cv_image)
            cv2.waitKey(1)
        except CvBridgeError as e:
            print(e)
def main(args=None):
    rclpy.init(args=args)
    bounding_box_node = DrawBoundingBox()
    try:
        while rclpy.ok():
            rclpy.spin(bounding_box_node)
    except KeyboardInterrupt:
        pass
    cv2.destroyAllWindows()
    bounding_box_node.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
    main()
Hope it helps!
Note: Please be aware that the axis when trying to use the image geometry pinholecameramodel is a bit different than gazebo's axes.
see here
