Hello everyone.
I have a Realsense D435 camera on my application, and I use its depth_image to generate a laser scan topic with the package depthimage_to_laserscan. This works allright.
The problem I want to solve is when I generate obstacles with this laser topic, it marks me the obstacle but when I move and the obstacle get closer it updates the position of the obstacle but it does not lcear the previus marks of the obstacle.
Here you can see screenshots of the problems:
In the image above the obstacle layer is just generating marks where the sensor sees an obstacle (green line). But in the image below the obstacle gets close and it generates the new marks, but the old marks are not being cleared.
I think is an error of configuration parameters of local_costmap, so here it is the code:
costmap_common_params.yaml
footprint: [[-0.30 , 0.38], [0.70, 0.38], [0.70, -0.38], [-0.30, -0.38]]
laser_layer: #Laser
#track_unknown_space: false
#footprint_clearing_enabled: true
#combination_method: 1
observation_sources: laser
laser:
topic: /scan
sensor_frame: camera_depth_frame
#observation_persistance: 0.0
expected_update_rate: 0
data_type: LaserScan
clearing: true
marking: true
#max_obstacle_height: 2.0
#min_obstacle_height: 0.0
obstacle_range: 3.0
raytrace_range: 5.0
#inf_is_invalid: false
pointcloud_layer: #Nube de puntos
#origin_z: 0.0
#z_resolution: 0.2
#z_voxels: 10
#unknown_threshold: pointcloud_layer/z_voxels
#mark_threshold: 0
#publish_voxel_map: false
observation_sources: pointcloud
pointcloud:
topic: /camera/depth/color/points
data_type: PointCloud2
clearing: true
marking: true
obstacle_range: 3.0
raytrace_range: 5.0
inflation_layer:
inflation_radius: 0.75
#cost_scaling_factor: 10.0
local_costmap_params.yaml
local_costmap:
plugins:
- {name: static_map, type: "costmap_2d::StaticLayer"}
- {name: laser_layer, type: "costmap_2d::ObstacleLayer"} #Laser sensors
#- {name: pointcloud_layer, type: "costmap_2d::VoxelLayer"} #Pointcloud sensors
#- {name: ultrasonic, type: "range_sensor_layer::RangeSensorLayer"}
- {name: inflation_layer, type: "costmap_2d::InflationLayer"}
update_frequency: 2.0 #HIGH CPU usage with sensors
publish_frequency: 50.0 #Reducir para aligerar CPU
global_frame: "odom" #To inflate obstacles
robot_base_frame: "base_link"
#static_map: false
rolling_window: true
width: 6.0 #6
height: 6.0 #6
resolution: 0.05 #0.01
#always_send_full_costmap: true
global_costmap_params.yaml
global_costmap:
plugins:
global_frame: "map"
resolution: 0.5 #0.01 #The resolution of the map in meters/cell.
transform_tolerance: 0.2 #Specifies the delay in transform (tf) data that is tolerable in seconds
map_type: costmap
base_local_planner_params.yaml
#recovery_behavior_enabled: false
#clearing_rotation_allowed: false
controller_frequency: 10 #Default 20 took many time
TrajectoryPlannerROS:
max_vel_x: 0.4 #meters/sec #0.6
min_vel_x: -0.1
max_vel_y: 0.0 # zero for a differential drive robot
min_vel_y: 0.0 #radians/sec
max_vel_theta: 1.0 #3
min_vel_theta: -1.0
min_in_place_vel_theta: 0.1 #radians/sec, in-place rotations
escape_vel: -0.1 #0.1
acc_lim_x: 0.4 #meters/sec^2
acc_lim_y: 0.0 # zero for a differential drive robot
acc_lim_theta: 1.0 #radians/sec^2
holonomic_robot: false
#####Trajectory Scoring Parameters#####
meter_scoring: true #goal_distance and path_distance are expressed in units of meters or cells. Cells false.
#pdist_scale: 0.4 #The weighting for how much the controller should stay close to the path it was given
#gdist_scale: 0.8 #The weighting for how much the controller should attempt to reach its local goal, also controls speed
yaw_goal_tolerance: 0.5 # about 30 degrees, The tolerance in radians for the controller in yaw/rotation when achieving its goal
xy_goal_tolerance: 0.20 # 5 cm, The tolerance in meters for the controller in the x & y distance when achieving a goal
#latch_xy_goal_tolerance: false
#heading_lookahead: 0.325 #How far to look ahead in meters when scoring different in-place-rotation trajectories
#heading_scoring: false #Whether to score based on the robot's heading to the path or its distance from the path
#heading_scoring_timestep: 0.8 #How far to look ahead in time in seconds along the simulated trajectory when using heading scoring
occdist_scale: 0.07 #The weighting for how much the controller should attempt to avoid obstacles
#dwa: false
#####Oscillation Prevention Parameters######
#oscillation_reset_dist: 0.05 #How far the robot must travel in meters before oscillation flags are reset
####Others#######
#publish_cost_grid_pc: false
#prune_plan: true
#simple_attractor: false
####Forward Simulation Parameters####
sim_time: 3.0 #The amount of time to forward-simulate trajectories in seconds
sim_granularity: 0.05 #The step size, in meters, to take between points on a given trajectory
#angular_sim_granularity: 0.15 #The step size, in radians, to take between angular samples on a given trajectory
vx_samples: 10 #The number of samples to use when exploring the x velocity space
vy_samples: 0 # zero for a differential drive robot
vtheta_samples: 20.0
If anyone know the configuration to mark just the obstacles that the laser is seeing I would be very thankfull.
Best regrets. Alessandro
P.S.: Sorry for my english, if you do not understand something just ask me :).
EDIT
Finally I solved it using other type of layer (Spatio Temporal Voxel Layer) and generating a mark layer with the LaserScan topic with a voxel decay of 0.75 seconds. The configuration of the layer is the following:
laser_layer_temp:
enabled: true
voxel_decay: 0.75 #seconds if linear, e^n if exponential
decay_model: 0 #0=linear, 1=exponential, -1=persistent
voxel_size: 0.05 #meters
track_unknown_space: true #default space is unknown
observation_persistence: 0.0 #seconds
max_obstacle_height: 2.0 #meters
unknown_threshold: 15 #voxel height
mark_threshold: 0 #voxel height
update_footprint_enabled: true
combination_method: 1 #1=max, 0=override
obstacle_range: 3.0 #meters
origin_z: 0.0 #meters
publish_voxel_map: true # default off
transform_tolerance: 0.2 # seconds
mapping_mode: false # default off, saves map not for navigation
map_save_duration: 60 #default 60s, how often to autosave
observation_sources: rgbd1_mark
rgbd1_mark:
topic: /scan
marking: true
clearing: false
#min_obstacle_height: 0.3 #default 0, meters
#max_obstacle_height: 2.0 #defaule 3, meters
expected_update_rate: 0.0 #default 0, if not updating at this rate at least, remove from buffer
observation_persistence: 0.0 #default 0, use all measurements taken during now-value, 0=latest
inf_is_valid: false #default false, for laser scans
clear_after_reading: true #default false, clear the buffer after the layer gets readings from it
voxel_filter: true #default off, apply voxel filter to sensor, recommend on
voxel_min_points: 0 #default 0, minimum points per voxel for voxel filter
Best regards. Alessandro
Originally posted by Alessandro Melino on ROS Answers with karma: 113 on 2020-03-17
Comment by stevemacenski on 2020-03-17:
Please upload your images to the answer so they are retained.
Comment by Alessandro Melino on 2020-03-18:
The platform doesn't let me upload images because I am less than 5 points. Can't you see them using the links?
Here you are another links to see the images.
Thank you for your response.
Comment by gvdhoorn on 2020-03-18:
Please attach the images to your question now. I've given you sufficient karma.
Thank you! It's done.
