Hi I am semi-new to ROS and am trying to run the tutorial.launch file in hectorSLAM and I’ve hit a roadblock and keep getting an error when I try to run the tutorial.launch.
I cloned HectorSLAM for melodic from https://github.com/tu-darmstadt-ros-pkg/hector_slam
I am running Ubuntu 18.04.4 and ROS melodic.
The launch file is located in ~/a_ws/src/hector_slam/hector_slam_launch/launch and I run:
administrator@administrator-OptiPlex-3010:~/a_ws/src/hector_slam/hector_slam_launch/launch$ roslaunch tutorial.launch
I then get the following error:
RLException: Invalid <arg> tag: hector_geotiff
ROS path [0]=/opt/ros/melodic/share/ros
ROS path [1]=/home/administrator/a_ws/src
ROS path [2]=/opt/ros/melodic/share
Argxml is <arg default="$(find hector_geotiff)/maps" name="geotiff_map_file_path"/>
The traceback for the exception was written to the log file
I have tried to launch the file multiple times and sometimes I get the error:
ROS path [1]=/opt/ros/melodic/share
I have set roscd as ~a_ws/devel and the HectorSLAM package has the hector_geotiff package in it
any help fixing this error would be greatly appreciated.
Originally posted by Nosnik on ROS Answers with karma: 3 on 2020-03-11
