I installed Multiple versions of APM (2.0.7, 2.0.17, 2.0.18) on Windows 7, Ubuntu 14.04, and OSX 10.11. I could connect to my ArduPilot but could not install firmware. Here's the error I would get:
Started downloading http://firmware.diydrones.com/Copter/stable/apm2-hexa/ArduCopter.hex
Finished downloading /var/folders/r4/s_j4c02s3wvcx6wy41__rnwh0000gp/T/APM Planner.uq1800
Opening firmware file...
Unable to open file: /var/folders/r4/s_j4c02s3wvcx6wy41__rnwh0000gp/T/APM Planner.uq1800
For hours I've been dealing with this and no one has documented the same issue online. I tried the following with no success:
  • Changed permissions of parent folder /var/folders/r4/s_j4c02s3wvcx6wy41__rnwh0000gp/T
  • Ran APM as sudo
  • Multiple versions of APM
  • Multiple operating systems
I had to get a bit creative to come up with a workable solution:
Solution
When APM tried to download the firmware, you could see the temp file until you clicked "OK" in regard to the firmware failure. What I did was copied that file and found the following html in there:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>302 Found</title>
</head><body>
<h1>Found</h1>
<p>The document has moved <a href="http://firmware.ardupilot.org/Copter/stable/apm2-hexa/ArduCopter.hex">here</a>.</p>
<hr>
<address>Apache/2.4.7 (Ubuntu) Server at firmware.diydrones.com Port 80</address>
</body></html>
Obviously this is a server issue so here's what I did to get around it:
  • Downloaded the file mentioned in the html (http://firmware.ardupilot.org/Copter/stable/apm2-hexa/ArduCopter.hex) to my desktop
  • Changed the file format from txt to hex
  • Set APM Planner to advanced mode via File > Advanced Mode
  • In Initial Setup > Install Firmware Menu I selected Firmware Options > Custom
  • Chose the hex file I had downloaded
Violá
