If you run the following command in the root of your workspace folder, it will search through all the package.xml
files in the src
directory and automatically install missing package binaries using apt
rosdep install --from-paths src --ignore-src -r
Make sure rosdep
is up to date first:
rosdep update
Any package included as a <depend>
, <exec_depend>
, <build_depend>
etc. in any package.xml
will be found by the command, so make sure all packages you need to build or run a package are listed it its package.xml
Originally posted by robustify with karma: 956 on 2020-03-06
Comment by gvdhoorn on 2020-03-07:
Note: this will only install system dependencies when building ROS from source.
It will not install / fetch missing ROS packages.
Comment by phil123456 on 2020-03-07:
s@#t...ok well I'll do this manualy
Comment by gvdhoorn on 2020-03-08:
No, that's not necessarily needed. I just wanted to draw attention to the fact that what @robustify writes is not a complete answer to your question.
If we're talking about packages that have been released, you could try something like this:
rosinstall_generator <the_package> --rosdistro <your_distro> --deps --tar --exclude RPP > the_package_deps.rosinstall
this will ask rosinstall_generator
to generate a list of files/repositories to download (actually: .tar
files) which you then merge into your workspace using wstool
. Then you can run rosdep
, which installs the system dependencies, and then you can run catkin_make
See also #q346123 for a recent Q&A about this procedure.
Comment by phil123456 on 2020-03-09:
I am talking about raspbery pi 4 and the fact that I had to compile ROS from the appropriate tutorial
I'll try to use rosdep, but I am pretty sure, I'll end up doing this on my RPI3 in the end :-(
-bash: rosinstall_generator: command not found
but 'rodep update' and 'rosdep install --from-paths src --ignore-src -r' installed some packages
then I could go further installing hector slam...it installed opncv deps , but I keep having unmet dependencies, so I install them manualy
Comment by gvdhoorn on 2020-03-09:
is not installed by default. On platforms without .deb
packages, you'd have to install it using pip install rosinstall_generator
. The same goes for rosdep
Comment by phil123456 on 2020-03-10:
ok but I have an error about some package being not homogenous and such, I checked the logs and there are some compilation errors, I decided to stop tinkering with an unfinished ros package, I'll try on a RPI3 ready to go image
Comment by gvdhoorn on 2020-03-10:\
that's most likely an error printed by catkin_make
, which it prints whenever you have packages with a build type other than catkin
in your workspace. It should also tell you to use catkin_make_isolated
to build workspaces like that (catkin_tools
can also build them).
I decided to stop tinkering with an unfinnished ros version
ROS Melodic is far from "unfinished". It's in production use in countless applications.
RPi support (all of them actually, not just the 4) is community contributed. That doesn't mean it's any less valuable, but unless someone from the community decides to keep it up to date, there are bound to be problems on newer platforms.
ok but since I added packages manualy, I have no idea what to do, do I remove them ? I am a complete ROS noob
and I 'd rather avoid compile stuffs, I have done enough manual add/compile... yet I am nowhere on the path of learning ROS
I'll try the ubiquity image
actualy I could make my lidar work but now I want hector slam to be installed, it ends up with some weird QT compilation issues...digging in google, it appears nobody had that error on ROS, so maybe I reached the limit of working pakages on RPI4/melodic
