I'm running Ubuntu 16.04 via WSL, installed ROS Kinetic to work with my E-puck2 robot, I created a catkin_workspace and installed all dependencies, there was no error when I issued catkin_make command, issued roscore command on another terminal and it started roscore service. I sourced my files on another terminal using
source ~/catkin_ws/devel/setup.bash
chmod +x ./src/epuck_driver/scripts/epuck2_driver.py to mark the driver node as executable
roslaunch epuck_driver epuck2_controller.launch epuck2_address:='b4:e6:2d:ed:07:a7'
with MAC address according to my e-puck's, the roslaunch server started, listing a summary of parameters and nodes, but then the rviz process died and epuck's process died too. The E-puck's process keep restarting and dying. Could anyone please help me out?
Originally posted by yabdulra on ROS Answers with karma: 23 on 2020-03-04
First: WSL is not a supported runtime environment for ROS. It comes with a special set of requirements and constraints that none of the ROS packages have been tested for. You can certainly try to use ROS in a WSL environment, but know that you'll most likely run into difficulties.
Having written that: if the driver requires access to hardware, it's likely it can't work in WSL, as WSL does not support direct access to hw. If it just needs a network connection, it may work.
As to RViz: WSL does not come with an X-server, so GUI applications will not work by default. You'll have to install an X-server on the Windows side. There are a few Q&As about this here on ROS Answers you may want to look up (use Google, and append site:answers.ros.org to your search query). But even with an X-server there is no guarantee running RViz (and/or Gazebo) will work.
Originally posted by gvdhoorn with karma: 86574 on 2020-03-05
Comment by yabdulra on 2020-03-05:
Thank you for this comment. I'll install Ubuntu alongside widows and start all over.
Comment by yabdulra on 2020-03-08:
I'm using ROS on a VM installed ubuntu, and these problems are no more now. Thank you once again.
