Hello,
I want to ask one question and hopefully someone will help me with that. I am not so professional.
Is it possible to use ros_control pkg with open loop system. I mean I have a stepper motor without encoder, so I don't have the position of the motor, I calculating it just by summarize every time my command in pulses to the motor.
Because, as far as I understand the ros_control pkg require the close loop system to control it with PID.
Thank you in advance!
Originally posted by Yehor on ROS Answers with karma: 166 on 2020-03-03
This is actually not entirely correct.
Some controllers in ros_controllers are closed-loop, but there are quite a few which are actually open-loop (so called command forwarding controllers). For instance: all controllers which take a position setpoint and output a position (ie: position_controllers/JointPositionController) are completely open-loop (see here).
So: yes. This would be possible.
If you implement a hardware_interface that simply copies command -> current_state (perhaps with a small delay) then none of the controllers will ever notice this.
Originally posted by gvdhoorn with karma: 86574 on 2020-03-03
