Hi,
I'm new to ROS and currently working on using rtabmap with move_base and the zed camera on a jetston-tx2 for Navigation.
I start the roscore on the Host machine.
Than I start the zed node on the robot.
$ roslaunch zed_wrapper zed.launch
During the start the following error comes up:
...[ INFO] [1582724028.740786655]: depth_frame: depth_frame
Couldn't find an AF_INET address for [hostname]
ZED (Init) >> Depth mode: PERFORMANCE
ZED (Init) >> Video mode: HD720@30
At this point I can see the topcis published by the zed camere via rostopic list and via rqt, but any rtabmap or rviz application I start returns something similar to this:
...[ WARN] [1582724056.543819469]: /rtabmap/rtabmap: Did not receive data since 5 seconds! Make sure the input topics are published ("$ rostopic hz my_topic") and the timestamps in their header are set. If topics are coming from different computers, make sure the clocks of the computers are synchronized ("ntpdate"). Parameter "approx_sync" is false, which means that input topics should have all the exact timestamp for the callback to be called.
    /rtabmap/rtabmap subscribed to (exact sync):
   /rtabmap/odom,
   /zed/zed_node/left/image_rect_color,
   /zed/zed_node/right/image_rect_color,
   /zed/zed_node/left/camera_info,
   /zed/zed_node/right/camera_info,
   /rtabmap/odom_info
Meanwhile in the zed node terminal:
...[ WARN] [1582724033.052059891]: The tf from 'base_frame' to 'camera_frame' does not seem to be available, will assume it as identity!
Couldn't find an AF_INET address for [hostname]...
Additional Information:
On host machine: ros_kinetic, Ubuntu 16.04, 4.15.0-76-generic
On jetson-tx2: ros_kinetic, Ubuntu 16.04, 4.4.38-tegra, zed_wrapper: 2.8.x
Regarding the AF_INET address error i already tried this: https://answers.ros.org/question/163556/how-to-solve-couldnt-find-an-af_inet-address-for-problem/
But that didnt change anything for me.
I also wrote two tf static_transform_publisher which added the camera_frame and base_frame into the existingt tf_tree. After I had done that the frames where in the tf_tree and there was a transform between them but the error message still appeared. I would rather change that directly in the zed_urdf but I can't find where they're defined.
It would be very much appreciated if You could give me some idea on what to look into.
Best regards, Uwe
Things I tryed so fa, but didn't work out: -Reinstall rtabmap -Built rtabmap from source -Run diffrent examples -Turn approx sync = true
Edit: I now have tried running the example (http://wiki.ros.org/rtabmap_ros/Tutorials/StereoHandHeldMapping) on the jetson itself and I got the same error message. The Topics are being publish and aren't empty.
Edit: After editing the urdf (https://github.com/stereolabs/zed-ros-wrapper/blob/3c643fc9f75f1053db31931542fda7ac149a2ff3/zed_wrapper/urdf/zed_descr.urdf.xacro#L51) and deleting a static tf transform (which I forgit about) I could run the rtabmap example (http://wiki.ros.org/rtabmap_ros/Tutorials/StereoHandHeldMapping) on the jetson. If I try to do remote mapping now, I wont get any error messages about not receiving messages, but rtabmapviz wont show any output.
Originally posted by Uwe on ROS Answers with karma: 3 on 2020-02-26
Comment by Uwe on 2020-02-26:
I fixed the AF_INET Error by following http://wiki.ros.org/ROS/NetworkSetup
Comment by matlabbe on 2020-06-23:
Make sure you are receiving topics on the remote computer. If not, check your ROS_IP. Is rtabmap logging at 1hz ? (making sure rtabmap is running)
The ZED creates its own base_link which I found to be problematic. Here is where it is created:
I added the frames from the ZED manually to my URDF and setting the publish_urdf argument to false for zed_camera.launch
https://github.com/bob-ROS/asc_project/blob/cc397c66f2c9a6b7bff4dc3b8e521d333297ec15/asc_description/urdf/asc.urdf_real.xacro#L205
  <link name="zed_camera_center">
    <visual>
      <origin xyz="0 0 0" rpy="0 0 0"/>
      <geometry>
        <mesh filename="package://asc_description/meshes/ZED/ZED.stl"/>
      </geometry>
      <material name="light_grey">
        <color rgba="0.8 0.8 0.8 0.8"/>
      </material>
    </visual>   </link>
  <joint name="base_to_camera" type="fixed">
    <origin xyz="0.149 0 0.49" rpy="0 -0.1 0"/> <!-- tune pitch here -->
    <parent link="base_link"/>
    <child link="zed_camera_center"/>   </joint>   <link name="camera_link_pc"/>   <joint name="camera_to_pc" type="fixed">
    <origin xyz="0 0 0" rpy="-1.57 0 -1.57"/>
    <parent link="zed_camera_center"/>
    <child link="camera_link_pc"/>   </joint>
     <!-- Left Camera -->   <joint name="zed_left_camera_joint" type="fixed">
    <child link="zed_left_camera_frame"/>
    <origin xyz="0 0.06 0" rpy="0 0 0"/>   </joint>   <link name="zed_left_camera_frame"/>   <joint name="zed_left_camera_optical_joint" type="fixed">
    <origin xyz="0 0 0" rpy="-1.57079632679 0.0
-1.57079632679"/>
    <parent link="zed_left_camera_frame"/>
    <child link="zed_left_camera_optical_frame"/> </joint>   <link name="zed_left_camera_optical_frame"/> <!-- Right Camera -->   <joint name="zed_right_camera_joint" type="fixed">
    <child link="zed_right_camera_frame"/>
    <origin xyz="0 -0.06 0" rpy="0 0 0"/>   </joint>   <link name="zed_right_camera_frame"/>   <joint name="zed_right_camera_optical_joint" type="fixed">
-1.57079632679"/>
    <parent link="zed_right_camera_frame"/>
    <child link="zed_right_camera_optical_frame"/> </joint>   <link name="zed_right_camera_optical_frame"/>
You could probably resolve this by rewriting the existing zed URDF file to not use the base_link and then connect your existing base_link to e.g. "zed_base_link".
Originally posted by bob-ROS with karma: 525 on 2020-02-27
Comment by Uwe on 2020-02-28:
Hey, thank you for your fast reply. I will try this asap. I think I still misunderstand something about the frames. Doesn't the zed camera also publish the frames base_frame and camera_frame? My tf tree looks pretty much like this: https://answers.ros.org/question/331367/mapping-with-zed-camera/
Comment by bob-ROS on 2020-02-28:
What frames does your robot have?
Comment by Uwe on 2020-03-04:
Sry for replying so late. At the moment I'm just trying to run rtabmap on the jetson an drive the robot via remote control through an eviorment for stereo mapping, so I didnt attach the Robotframes.
Comment by bob-ROS on 2020-03-04:
I don't think it is a frame problem. "approx_sync" is false, which means that input topics should have all the exact timestamp for the callback to be called. So I assume you didn't run the existing example. Check this example out
Comment by Uwe on 2020-03-05:
I also tried to turn "approx_sync" true, but it didn't change the outcome. It just erased the sentence from the error output in the terminal. I can try this example tomorrow and will report on the outcome. Thank you for your help so far. :)
Comment by Uwe on 2020-03-07:
The example you sended me ist the zed example which dosen't work for remote mapping, or does it? I wish to start the camera on the robot and rtabmap on the remote computer which ist hosting the roscore. I thougth maybe I should this http://wiki.ros.org/rtabmap_ros/Tutorials/RemoteMapping tutorial first, but I got a diffrent error now. I guess I should wirte a new thread about that error now. Am I right about this? Asking because the structure of message boards for asking questions is new to me.
Comment by bob-ROS on 2020-03-07:
I would recommend having the robot as the master, which Matlabbe also does in that tutorial.
Yes, I agree this would be better. At the moment I'm not able to change that circumstance, due to other partys working on the robot and some errors which were solved doing it this way around. If that would be the definitive origin of my erros though, I would look into that.
Comment by Uwe on 2020-03-11:
Now a router is the rosmaster and connects the jetson and the laptop, but the problem persists.
Comment by Uwe on 2020-04-29:
Rviz can catch the topics and i can display the pointcloud with it but rtabmap still dosent recieve any topics. I pretty much in a dead end.
Comment by matlabbe on 2020-04-29:
zed_ros_wrapper has changed over time, see my answer for the latest version.
Comment by Uwe on 2020-06-05:
It seems I forgot about a static transform I implemented which may have caused the error. I won't get any error messages about not receiving messages now, but rtabmapviz wont show any outputs. Though I guess my question is kinda answered, because rtabmap seems to get the messages now.
Updated answer for the most recent zed_ros_wrapper version (April 2020).
There is an issue where images published by the zed node don't have always the same stamps, causing synchronization issues (large latencies) for rtabmap. Make sure your have this pull request. Refer to this rtabmap+zed tutorial, which has been also updated.
With rtabmap odometry:
$ roslaunch zed_wrapper zed_no_tf.launch
$ rosrun dynamic_reconfigure dynparam set zed_node depth_confidence 99
$ rosrun dynamic_reconfigure dynparam set zed_node depth_texture_conf 90
$ rosrun dynamic_reconfigure dynparam set zed_node depth_confidence 100
$ roslaunch rtabmap_ros rtabmap.launch \
    rtabmap_args:="--delete_db_on_start" \
    rgb_topic:=/zed_node/rgb/image_rect_color \
    depth_topic:=/zed_node/depth/depth_registered \
    camera_info_topic:=/zed_node/rgb/camera_info \
    frame_id:=base_link \
    approx_sync:=false
With zed odometry:
$ roslaunch zed_wrapper zed2.launch
$ rosrun dynamic_reconfigure dynparam set /zed2/zed_node depth_confidence 99
$ rosrun dynamic_reconfigure dynparam set /zed2/zed_node depth_texture_conf 90
$ rosrun dynamic_reconfigure dynparam set /zed2/zed_node depth_confidence 100
    rgb_topic:=/zed2/zed_node/rgb/image_rect_color \
    depth_topic:=/zed2/zed_node/depth/depth_registered \
    camera_info_topic:=/zed2/zed_node/depth/camera_info \
    odom_topic:=/zed2/zed_node/odom \
    visual_odometry:=false \
    approx_sync:=false \
    rgbd_sync:=true \
    approx_rgbd_sync:=false
Comment by Uwe on 2020-04-30:
Thank you, I will try this as soon as I can return to the robot.
I had a chance to try this, but for the updated zed-ros-wrapper I need CUDA 10 and fo that I have to flash the jetson, if I'm not mistaken. The Problem is that it would be very difficult for me because there are multiple Users who use this jetson and I'm not sure on how this would affect their work.
Edit: I will still try to flash it since I notice it seems to be very hard to provide answers to someone who uses outdated packages.
