Hi, I am compiling micro-ROS crystal version and want to run the publisher demo for Int32. However, I get the following error:
undefined reference to `rosidl_typesupport_c__get_message_type_support_handle__std_msgs__msg__Int32'
I think this function should be defined somewhere but it seems that it has not been defined. Would you please tell me in which library I should find this function? Thanks
Originally posted by Saeid Dehnavi on ROS Answers with karma: 11 on 2020-02-18
Comment by gvdhoorn on 2020-02-19:
You may want to post this as an issue on the appropriate micro-ros issue tracker. The intersection between micro-ros developers/users and ROS Answers frequenters is probably not very big, so it may take quite some time before you get a response here.
Comment by Saeid Dehnavi on 2020-02-19:
Thanks @gvdhoorn, but since this problem is related to the ROS typesupport which is shared between normal ROS2 and microROS, I decided to post my question here :)
Comment by Dirk Thomas on 2020-02-19:
@gvdhoorn I would highly recommend the micro-ros developers to watch answers.ros.org and specifically the micro-ROS tag.
@saeid-dehnavi I have add the micro-ROS tag to your question since the problem happens when you compile micro-ROS.
Comment by gvdhoorn on 2020-02-19:\
Couldn't agree more, but I'm not one of them. Nor do I talk to them often.
The symbol should be in install/lib/libstd_msgs__rosidl_typesupport_c.so for humble.
$ nm install/lib/libstd_msgs__rosidl_typesupport_c.so | grep rosidl_typesupport_c__get_message_type_support_handle__std_msgs__msg__Int32
00000000000044fc T rosidl_typesupport_c__get_message_type_support_handle__std_msgs__msg__Int32
000000000000454b T rosidl_typesupport_c__get_message_type_support_handle__std_msgs__msg__Int32MultiArray
Originally posted by yashi with karma: 26 on 2022-10-09
Does this issue still persist with newer versions (for Dashing or ideally Foxy)? We have improved the tutorials a lot in the last months. Please let us know if you face any issues with them. If you want to start with real microcontroller hardware, I recommend https://micro-ros.github.io/docs/tutorials/core/first_application_rtos/freertos/. If you use an ESP32, the wiring is even simpler than with the Olimex STM32-E407. And, we promise to watch answers.ros.org more intensively!
Originally posted by ralph-lange with karma: 31 on 2021-01-22
