Ubuntu 18.04
ROS2 Eloquent (installed by binaries)
I am trying to transform a PoseStamped in the target frame in python.
Below would how my code look like:
import tf2_geometry_msgs
from geometry_msgs.msg import PoseStamped
target_pose_s = self.tf_buffer.transform(self.pose_s, target_frame)
In this case, I get module not found error:
ModuleNotFoundError: No module named 'tf2_geometry_msgs'
I think it is looking for the tf2_geometry_msgs.py file, which is not installed for ROS2 on my system. But I can see this for melodic.
/opt/ros/melodic/lib/python2.7/dist-packages/tf2_geometry_msgs/tf2_geometry_msgs.py
(it exists in the eloquent branch though)
In this issue, which was addressed in this PR the setup.py was said to be "unused". Also here is marked that Python support doesn't exist yet, though catkin_python_setup() shouldn't be needed for ROS2 anymore?
If I comment out tf2_geometry_msgs, I get the error
tf2_ros.buffer_interface.TypeException: Type <class 'geometry_msgs.msg._pose_stamped.PoseStamped'> if not loaded or supported
What am I missing here? Or is it that transform(PoseStamped, "target_frame") function not supported yet in Python?
Originally posted by ipa-hsd on ROS Answers with karma: 150 on 2020-02-13
In my understanding the tf2_geometry_msgs are not build for python (the binding) in ros eloquent, you need this pullrequest, and thus move to a more recent ros2 version (i.e master for now): https://github.com/ros2/geometry2/pull/207
Originally posted by lgeorge with karma: 123 on 2020-05-19
