This has been a major pain point for me when porting a big ROS1 code base that made synchronous service calls all the time deep inside libraries. My preferred solution to this is setting up the node and client so that the service response arrives on another thread. Then the code calling the service can just do future.get()
or future.wait()
to wait for the response. You need to:
In general I try to do this and avoid use of spin_until_future_complete
whereever possible because I don't want my internal application logic coupled with the spinning/execution of my node. Maybe we'll get some API updates in a future release that makes this easier, especially with having to handle callback group objects explicitly.
Edit: Including a full standalone example to clearly show how to do this. Here a node calls a service advertised by the same node from within the callback of a different service.
#include <rclcpp/rclcpp.hpp>
#include <std_srvs/srv/trigger.hpp>
class TwoSrvs : public rclcpp::Node
public:
TwoSrvs() : Node("two_srvs")
callback_group_ = this->create_callback_group(rclcpp::callback_group::CallbackGroupType::Reentrant);
outer_srv_ = this->create_service<std_srvs::srv::Trigger>("outer_srv",
std::bind(&TwoSrvs::outer_cb, this, std::placeholders::_1, std::placeholders::_2),
::rmw_qos_profile_default,
callback_group_);
inner_srv_ = this->create_service<std_srvs::srv::Trigger>("inner_srv",
std::bind(&TwoSrvs::inner_cb, this, std::placeholders::_1, std::placeholders::_2),
callback_group_);
client_ = this->create_client<std_srvs::srv::Trigger>("inner_srv");
void outer_cb(std_srvs::srv::Trigger::Request::SharedPtr, std_srvs::srv::Trigger::Response::SharedPtr res)
using namespace std::chrono_literals;
RCLCPP_INFO(get_logger(), "outer srv callback");
auto req = std::make_shared<std_srvs::srv::Trigger::Request>();
auto future = client_->async_send_request(req);
RCLCPP_INFO(get_logger(), "outer srv called inner srv");
auto status = future.wait_for(3s); //not spinning here!
if (status == std::future_status::ready)
RCLCPP_INFO(get_logger(), "inner srv response is %s", future.get()->message.c_str());
res->success = true;
res->message = "good";
else
RCLCPP_ERROR(get_logger(), "inner srv future wait failed");
res->success = false;
res->message = "bad";
void inner_cb(std_srvs::srv::Trigger::Request::SharedPtr, std_srvs::srv::Trigger::Response::SharedPtr res)
RCLCPP_INFO(get_logger(), "inner srv callback");
rclcpp::callback_group::CallbackGroup::SharedPtr callback_group_;
rclcpp::Service<std_srvs::srv::Trigger>::SharedPtr outer_srv_;
rclcpp::Service<std_srvs::srv::Trigger>::SharedPtr inner_srv_;
rclcpp::Client<std_srvs::srv::Trigger>::SharedPtr client_;
int main(int argc, char* argv[])
rclcpp::init(argc, argv);
auto node = std::make_shared<TwoSrvs>();
rclcpp::executors::MultiThreadedExecutor exec;
exec.add_node(node);
exec.spin();
Originally posted by jdlangs with karma: 971 on 2020-06-08
Post score: 5
Comment by MrCheesecake on 2020-07-16:
I tried your code and also modified my code in this way. 25-90% of the service calls from a node or the command line tool are bad.
I'm using dashing, does this change anyting? How is it in eloquent or foxy?
I also did tests on eloquent and foxy now, but the results have been more bad.
But I found a fix which works for me. The fix is to also use MultiThreadedExecutor
and add the client calling the service to a CallbackGroup
. Adding the called service to a CallbackGroup
if it don't call another is not needed I believe.
But thank you @jdlangs for pointing into the right direction for me.
Comment by albert.arla on 2022-06-15:
Hi, I'm trying to apply this solution to my code, but I'm having some troubles. It seems all to work fine but after calling future.wait_for(3s) my node dies with the error: std::future_error: Broken promise. Any idea of how to solve it? Thanks!
